ziggurcat
I'll try to be as succinct as I can with this so here goes nothing...
I'm trying to set myself up so that any future format upgrades (i.e. 8k, for example) doesn't require the purchase of multiple components since I've reduced my system into a 2.1ch music/HT build. The idea is to become less reliant on keeping up with HDMI technologies so that I'm not constantly upgrading my receiver every few years or so (not that I have to, but still...). As I was mulling things over, the Yamaha R-N800A became a consideration because it is pretty simple, doesn't have a lot of extra things I'll never use, and it has some form of room correction in YPAO. Unfortunately, there isn't a lot of 2ch receivers that have any form of room correction, so I don't have a lot of choice.
Fast forward to yesterday/today where I have re-calibrated my system using OCA's ART method because his Audyssey One method suggested that I inverted my sub's polarity (the log it generates indicated it was nearly 180 degrees out of phase with my speakers). And because I keep looking into simplifying things even further, I have been toying with the idea of dropping my subwoofer. The impetus for this comes from switching my AVR settings to turn the subwoofer on/off as I listen to some of my usual test racks, and the Lintons I have on their own (EQ'd, mind you) have held up where the bass presence is just as strong without the subwoofer going. If I drop my sub, then I can go with a simpler 2ch integrated amp that has pre-outs (I use external amplification for my speakers), but they often do not have any sort of room correction outside of the tone controls (which wouldn't cut it because I have room issues that only EQ can fix). I have been ogling the Leak 130/230 integrated for a while, now, and I think this would be my likely choice, but it clearly doesn't have any room correction software.
So I am going to start looking into some external DSP solutions in the event that this is the route I go. The problem is I have no idea where to begin. I have looked into miniDSP, but I have also read that while it's a pretty a nice thing for EQing/aligning subs, it's not so good for speaker calibration (there's mention of it creating artefacts, etc... but nothing I've read has been specific with what those issues are?). I would ideally like it to be reasonably affordable (I'm not looking to spend an extra $1k on this), and also available in Canada (or at least something I can order in, but being up here, things from the US can cost upwards of 50%+ more because of exchange rates/shipping/duty/taxes).
Thanks in advance for all of your time, and consideration.
