Chimiel
- Joined
- May 9, 2022
- Messages
- 39
- Likes
- 18
Hi,
I have the Neumann KH420 + miniDSP Flex Dirac room EQ. The Dirac app let's you choose between a focussed and wide sweet spot.
For the couch in our living room I've chosen the wide sweet spot, and Dirac is a night and day difference.
Here it comes:
I'm curious about upgrading with two KH750 subwoofers and using the MA-1 room correction for the KH750 + KH420 combination
(not a necessity, given the frequency range of the KH420's tamed by Dirac, just curious)
I've heard and seen in YouTube manuals that you have to anally measure your sweet spot to the centimeter in the Neumann app,
and that distance between the monitors, should also be distance to the listening position: a = b = c.
That won't be possible in my living room; the distance between the monitors is 3,5 meters, distance to center listening postion on my couch is about 4 meters.
(positioning the monitors wider puts my right monitor in the corner of the room and causes some serious peaks according to REW)
And I have a listening area on the couch about 2,5 meters wide.
Does anyone happen to know if my listening position renders Neumann MA-1 correction useless ?
Kind regards,
Michiel
Here it comes:
Kind regards,
Michiel
