Keith_W
I have no idea what a convolver is
A convolver takes your music signal and modifies it as per instructions from your filter. Convolvers can be used as crossovers. It takes an incoming music signal, makes a copy of it, and applies a high pass filter to one copy, a low pass filter to the other copy, then out it goes into the DAC. Convolvers can have all sorts of other features, e.g. some can host VST's, some have an ISO226 volume control, some apply additional processing ... but IMHO the most important feature is A-B switching.
MiniDSP has a built-in convolver. Other convolvers exist as software programs you run on your PC. Some others are built in to music players, e.g. JRiver and Roon have built-in convolvers. How you want to do your convolution is a matter of philosophy. For me personally, I value modularity and flexibility so I like being able to choose my own convolver. Others value simplicity and robustness. A convolver on a PC may break from a bad update, whereas a MiniDSP is far less likely to break.
