radix
- Joined
- Aug 1, 2021
- Messages
- 1,409
- Likes
- 1,346
Here's what I got for the T101 wall mounted. My wall is a 50* angle, so it's mounted on the metal bracket flush. It makes about a 27* angle up from the MLP. These tests used the UMIK-2 pointed vertical and the 90* calibration file. The mic is in the middle of the room 109cm from the speaker, roughly in-line from the height to the couch.
The Denon 6700 was set to 40 Hz crossover. The input was via the DVD HDMI from my Macbook Pro. Everything is at 48 kHz, 24-bit. I could not find an easy way to determine if Audyssey is enabled -- it was greyed out in the menu, but maybe that's because I set it via the app? In any case, the T101 is hooked up to the SBL amp output, which I've never EQ'd. The height outputs are not available from REW, so I used SBL as a stand-in.
Let me know if you'd like to see the data another way.Or I could post the mdat.
EDIT: here is a link to the mdat file.
I will make some additional measurements from the MPL later.
