That’s stupid, if it comes out due to vibration due to the playback, it’s extreme poor design if a speaker changes its sound due to playing back of sound. But transportation problems is acceptable as long as they mention this in the manual.They can get out due to transportation or vibration during music reproductuon. So just push them in from time to time.
Did you know screws on your speakers loosen over time and affect sound? Oh, what a poor design!That’s stupid, if it comes out due to vibration due to the playback, it’s extreme poor design if a speaker changes its sound due to playing back of sound. But transportation problems is acceptable as long as they mention this in the manual.
They shouldn't. Imagine if critical screws in a moving vehicle loosened over time.Did you know screws on your speakers loosen over time and affect sound? Oh, what a poor design!
Unfortunately they do. Sometimes.Imagine if critical screws in a moving vehicle loosened over time
Not just the design, but also reasons of using these (one of the reasons of using those rings - "let's get rid of ugly screws, we're going minimalistic") and causes of optimization - from making those flares just a flimsy plastic caps to assembling in China.if it comes out due to vibration due to the playback, it’s extreme poor design
It makes the tiniest, minutest, teensy little difference to the measured response.... I wouldn't let it worry me.That’s stupid, if it comes out due to vibration due to the playback, it’s extreme poor design if a speaker changes its sound due to playing back of sound. But transportation problems is acceptable as long as they mention this in the manual.
Mine moved during shipping (presumably), but have never moved in regular use. I don't think that actually happens.That’s stupid, if it comes out due to vibration due to the playback, it’s extreme poor design if a speaker changes its sound due to playing back of sound. But transportation problems is acceptable as long as they mention this in the manual.
I agree. All reports I have read about over the years are a result of shipping. Never from sound while playing.Mine moved during shipping (presumably), but have never moved in regular use. I don't think that actually happens.
They are not beauty rings. They have a purpose.Some of the beauty rings just loosen over time, some don't. It's a design flaw they fixed with the KEF R3 Meta, a dealer in Germany told me.
Just press them back in, if it bothers you a drop of glue will sort it.
Hide the ugly parts of the speaker?They are not beauty rings. They have a purpose.
erinsaudiocorner says it’s notIt makes the tiniest, minutest, teensy little difference to the measured response.... I wouldn't let it worry me.
On The KEF R Series and References as per kefs document itself it’s not a decoration but it’s something functional. I have not come across any other speaker ever which had its screws loosened over time. It is possible that very old poorly made speakers with particle boards can have this problem but that happens after several years.Unfortunately they do. Sometimes.
But yes:
Dynaudio got their portion of bad QC too after moving Evoke and cheaper lines to China (while BM and LYD are still marked as made in Denmark, I hope Danes don't lie).
Monitor Audio did it right many years before it became so mainstream - they used a central screw which goes from woofer to the back side of the speaker. No visible screws at the front panel and you can shape driver flare whatever you want. But there was a little thing they didn't manage those years (I didn't hear current models) and that was the sound
That’s from Erin’s audio corner. Again, it’s very easy to get this screwed if this part is not a fixed part to the baffle. I can easily push the ring (attempting to clean for example) on one corner and the opposite corner comes out more than 1 mm on my references. I have seen R Series boxes with the “beauty rings” protruding more than 1mm in the showrooms many times. If it was just a beauty ring, it wouldn’t have been a problem. But it is not. I bet majority of the R Series users are unaware of this issue and none of them are hearing what the reviewers heard!Hide the ugly parts of the speaker?
More than a beauty ring indeed, cheers.I can easily push the ring (attempting to clean for example) on one corner and the opposite corner comes out more than 1 mm on my references. I have seen R Series boxes with the “beauty rings” protruding more than 1mm in the showrooms many times. If it was just a beauty ring, it wouldn’t have been a problem. But it is not. I bet majority of the R Series users are unaware of this issue and none of them are hearing what the reviewers heard!
I never said these are not functional. They are. But that flare shape could be done another ways (MA screw-through-speaker is just one of examples). They way it stays fixed for years and no transportation drop that doesn't kill the speaker should make them move. Measurements you provided shows that it's critical for rings to be precisely on their right positions so it's KEF problem to assure this (if they care of course), not customer's.document itself it’s not a decoration but it’s something functional
Just decide if this is teensy little.It makes the tiniest, minutest, teensy little difference to the measured response.... I wouldn't let it worry me.
They seem to have solved it with the Meta refresh.I never said these are not functional. They are. But that flare shape could be done another ways (MA screw-through-speaker is just one of examples). They way it stays fixed for years and no transportation drop that doesn't kill the speaker should make them move. Measurements you provided shows that it's critical for rings to be precisely on their right positions so it's KEF problem to assure this (if they care of course), not customer's.
They never changed the cabinet design between R / Reference when they refreshed to Metas. From the looks and weight they are exactly the same. I do not know if they changed anything internally. The older cabins were well designed and is a good baseline for working on the drivers and crossovers. If I am not wrong if one has the money, they can buy the meta drivers and crossovers to Metafy the old one. Downside is having no warranty on doing so.They seem to have solved it with the Meta refresh.
It’s not loose on R3 either. It’s a press fit mechanism like a speaker grill. It’s possible to push on one corner and the opposite corner pops up. Using a hot glue would work but think of this: you are spending over 2000 euros on a speaker which has a high possibility of not sounding right, out of the box and need customers effort to make it right. This doesn’t happen on boxes costing 100 or even 25.So far we have no report of the R3 Meta rings coming loose, i would guess they add a dab of hot glue or something during assembly now.
Which is an option for those that have loose rings with the R3 too.
Mine arrived with the ring out of the baffle and I had to push it inside. You can read my post here:So far we have no report of the R3 Meta rings coming loose, i would guess they add a dab of hot glue or something during assembly now.
