KEF LS50 Bookshelf Speaker Review
D700
I've retired my LS50s to TV sound duty, running them with a Devialet 120. With the Devialet's SAM feature, the KEFs were unlistenable on movies: the bass was simply overloading anything else the speakers could do.
To resolve the problem, I picked up a $399 SVS SB-12 NSD from Amazon. Because I've been too busy and too tired to do measurements in the family room, I quickly found a recommendation from KEF that subwoofers be crossed over to the LS50s at 79 Hz and followed it, setting a 4th-order crossover to the KEFs at 79 Hz in the Devialet.
The sound is now superb for TV use, and with most listeners off-axis anyway, I think the LS50s plus a subwoofer are more or less ideal for two-channel "home theater." I will test it with music in due course.
Yeah, I followed same recommendations and use them with Velodyne Microvee, 50/50 Music/TV in a den, very happy.
maty
Tarragona (Spain)
I went from the Q150 to the LS50. My experience was that the LS50's cabinet is better built. Measurements suggest it is more innert as far as resonances go. That may or may not make it worth the doubling of price. As I understand it any ringing or resonances are a time domain problem and as a result cannot be effectively EQ'd out.
I certainly like the look of the blacked out LS50.
I was expecting more low frequency extension from the LS50 but that is not the case, they roll off very similarly and I was unsatisfied with the setup (given the cost) until I added a subwoofer (F12-300).
I read somewhere that the Q350 might be the better buy overall for more extension, and while I disregarded that advice initially they might have been on to something.
To listen to music, only the coaxial 5.25" has the magic. Either they have improved the Uni-Q 6.5" or I would avoid it. Of course, with very good recordings and high DR.
I am sure that with more mass + damping the Q150 would sound much better, as mine Q100. And with better components at the crossover. I have done the first process on some loudspeakers for years and always noticed improvement. With the Q100 the sound improvement was substantial!
AudioJester
Interesting discussion. I have both Rythmik and SVS subs, and prefer the servo sub by a long margin. Obviously many factors involved.
Howevee, can the Klippel system measure subs?
MZKM
Land O’ Lakes, FL
I believe Amir said it can.
Side note, @amirm, can the Klippel state at what simulated distance the measurements are being taken at after doing the extrapolation? Meaning, can it tell us how far away one needs to be for the drivers to fully integrate? I think that would be an interesting aspect to note.
MZKM
Land O’ Lakes, FL
Yes. But since response of a sub varies a ton in a real room, I am not sure of the value.
CEA-2010 rating for max passing SPL. As I mentioned elsewhere, data-bass.com is the best site for subwoofer measurements, Rythmik F18 as an example.
This is a max SPL discussion you can't get out of :p.
Group delay is also good (i guess waterfall and spectrogram show the same), it shows if the bass is "tight" or "loose".
AudioJester
Amir, would there me an advantage to having servo control for a subwoofer that would show up in measurements? Or is it all in my mind?
It can and it does. I don't currently have confidence in what it is showing however. As I test larger speakers, I can better tell how good that metric is. Here is what it looks like for KEF LS50 for example:
The highest order function flattens at about 0.6 meter where I have drawn that arrow. That means from there on we are in far field. Someone less lazy than me can do the math and tell us if this is correct:
It should show in distortion measurements assuming the implementation is good. The feedback mechanism varies between different implementations, some measuring current, others having sensors or secondary windings on the woofer itself.
MZKM
Land O’ Lakes, FL
Hmm, for this wouldn't you need to choose the frequency of the crossover region? Meaning, if it's mostly just the woofer playing 1000Hz, I don't know if the far-field distance for that is what's needed to answer the question.
jamestown
I am aware of that and hence the reason I am not sure frequency response measurement is of much value relative to how loud it can play.
That said, I need to build a larger platform for the Klippel system as subs can be quite a bit wider than speakers. I have bought an aluminum plate but then need to find the time to machine it and drill holes to mount it.
You mean the graph I posted or the text? The graph gives that answer implicitly. The more complex the soundfield, the higher the order needed to describe it. But once there, you have it regardless of what the source looks like.
bobbooo
The LFQ variable in Sean Olive's preference rating paper, defined as "Absolute average deviation (dB) in bass response from LFX to 300 Hz" in the sound power curve relative to the mean sensitivity in the listening window, had a contribution close to 20% in predicting preference in his initial formula. Admittedly this was based only on the first set of measurements (which I think were mostly/all stand-mounted speakers), but I think this is still good evidence that low-frequency quality (i.e. bass flatness), not just bass quantity (max SPL) or extension (LFX), does have a significant correlation with preference, and so LFQ should definitely be calculated for subwoofers (requiring the NFS to measure their frequency response), and possibly somehow incorporated into a subwoofer preference score.
BYRTT
Denmark (Jutland)
I went from the Q150 to the LS50. My experience was that the LS50's cabinet is better built. Measurements suggest it is more innert as far as resonances go. That may or may not make it worth the doubling of price. As I understand it any ringing or resonances are a time domain problem and as a result cannot be effectively EQ'd out.....
If those resonances measured is 100% reflection free minimum phase (MP) EQ also called analog or IIR filter in digital domain will smooth out those resonances both in amplitude domain and time domain, you can see it in examle below that MP response curves always have a phase pattern (time) that belongs to that particular response curve so on computers one curve is enough to compute/extract the other.
Cant know but will imagine when you talk the ringing cant be effectively EQ'd out as in below examples its because measured curve is not 100% reflection free so one try EQ out some none MP response and therefor waterfall wont clean up as it should, for acoustic domain measurements other reason to get errors than not 100% reflection free sweeps could be we often use few ADC/DAC units into measurement chain at varius rates and some of them can add their portion of excess phase if not calibrated.
aarons915
Chicago, IL
This Spin is fairly close to other measurements of the LS50 but one oddity I notice is the clear bump at 5k that I haven't seen in other measurements. Most seem to show an elevated region from 2-5k on axis but as you go off-axis, the 5K region smooths out while the 2k Resonance remains. The 2k region is almost always stronger than 5k except in this spin, which is a bit odd. Room measurements show the same thing, I've noticed it in my spatially averaged measurements and a few in this thread have posted measurements showing the 2k area with more energy than the 5k. I don't really have a question in all of that, just wanted to mention it since no one has brought it up.
