Maiky76
Hi,
Provided the decent results produced by the Kali IN8 (https://www.audiosciencereview.com/...udio-monitor-review.10897/page-51#post-413363) and Presonus 5 XT (https://www.audiosciencereview.com/...ctive-speaker-review.13436/page-3#post-477799)
I decided to do a similar work and see what their siblings were up to.
@amirm haven’t measured any of the 2 way 8inch but Audioholics did and provided graphs that I digitized and subsequently used to design some EQs as per usual.
Kali does provide some data see there:
https://www.kaliaudio.com/lone-pine-studio-monitors#lonepine-data-downloads
which is highly commendable but the resolution seems very low and not really suitable for my regular routines.
The contenders:
Kali LP8, 199USD/unit street price
Review from Audioholics
https://www.audioholics.com/bookshelf-speaker-reviews/kali-audio-lp-8
Presonus Eris E8 XT, 260USD/unit street price
https://www.audioholics.com/bookshelf-speaker-reviews/presonus-eris-e8-xt
Notes on the limits of the exercise:
Here is the synthesized Kali LP8 Spinorama with no EQ, score 6.24
One may notice the trough 785Hz that might be related to the BR port of the acoustic load just beneath the woofer, maybe similar to the JBL705
Also the HF response is very typical to a waveguide loaded dome tweeter.
Here is the synthesized Presonus Eris E8XT Spinorama with no EQ, score 5.73
It seems that there more voicing going on but I might be wrong...
Here is the comparison, both without EQ
The Kali looks both flatter and smoother, better out-of-the-box.
The speakers have clearly the similar attribute with regards to directivity i.e. ERDI and SPDI.
The EQs
Here is the EQ design for the Kali LP8:
Minimal work is required showing good optimization, the EQ would need to be carefully tested.
Score: 6.82
And the EQed Spinorama
Here is the EQ design for the Presonus Eris E8XT:
A bit more work to extract the most form this speaker
Score: 6.86
Finally the EQed comparison
Once EQed the speakers are very similar with probably the Eris might be sounding a bit clearer, see the Regression-tonal data attached.
Overall difficult to say which would be better only based on the EQed data alone.
They both look like bargains to me based on this set of data as they extend down to the mid 30s, seem to have a great directivity and with the amps and DRC built in can probably play fairly loud. I cannot see any consumer speaker competing with them at the same price.
One may add something like a Raspberry PI + audio interface + camilla DSP to have very decent system with all the bells and whistles at very low price.
In the case of the Kali the EQ might not even be needed...
It would be great if ASR could measure the LSR308, Yamaha HS8, ADAM T8V to get a good look at this type of speakers that may represent a sweet spot for many people. Even the Kali LP6, LSR306, Yamaha HS7,ADAM T7V would be great not only for the consumer market but, maybe more importantly, for music producers/the home studio crowd to try to break the audio circle of confusion…
The contenders:
- I have spliced the LF of the ON to the other curves and simulated the directivity, so it's probably not perfect but, I hope, a reasonable approximation.
- The scores are only indicative as the resolution of the scans, although interpolated to a correct 1/20th octave step, is most probably too coarse.
- The calculated scores are not directly comparable to the others form ASR but I would be inclined to say that the EQ benefits are correctly captured and the comparison between the two speakers is fair
- The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment.
The EQs
Score: 6.82
Code:
Type freq Gain Q
PEQ 130.0, 0.70, 2.70,...
PEQ 171.0, -0.43, 0.75,...
PEQ 362.0, 1.56, 4.51,...
PEQ 432.0, -1.58, 2.20,...
PEQ 2442.0, 1.24, 4.73,...
PEQ 3041.0, -0.67, 5.50,...
PEQ 3831.0, 0.86, 3.66,...
PEQ 17007.0, -3.56, 3.08,...
Score: 6.86
Code:
Type freq Gain Q
PEQ 86.3, -1.32, 1.97,...
PEQ 377.0, 1.10, 8.10,...
PEQ 687.0, -2.30, 9.50,...
PEQ 1431.0, -0.93, 2.07,...
PEQ 2212.0, 0.66, 3.66,...
PEQ 3225.0, -0.55, 7.00,...
PEQ 6513.0, 2.00, 2.45,...
PEQ 14400.0, -2.90, 3.70,...
