JPS Superconductor V USB Cable Review
Rate this USB Cable
  • 1. Waste of money (piggy bank panther)
    Votes: 283 96.9%
    Votes: 0 0.0%
    Votes: 1 0.3%
    Votes: 8 2.7%
antcollinet
UK/Cheshire
(as I type this on my 10 year old MacBook Pro) :confused:
Sort of negates the statement that they obsolete products. :p
I'm also typing this on a 10yo air. About to upgrade, and am mightily pissed off at the price apple is charging for the 32gb ram upgrade. But similar performance windows machines are heading towards similar prices, and I've never owned a windows laptop that is usable beyond 5 years.
So I'm probably going to have to hold my nose and pony up for a new macbook pro.
theREALdotnet
Well, in fairness -- Apple'd only charge $300, and they'd offer it in a palette of pleasant, stylish, and hardware-coordinated colours.
Wait, what? Apple sells a $300 USB cable? What kind of dollars is that, surely not US$?
EDIT The most expensive cable I can see on Apple’s site is US$159, and that’s a 3m 40Gbps Thunderbolt 4 cable.
RF Air
Desert Southwest, USA
Yes, I have the "collection" of PC Laptops that can't be thrown out but can't be used. This is the 2nd MacBook that has given me 10 years. Last one dropped it's HD and I bought this one with the SSD with no more fears. It's a tall pony for the new MacBook these days.
RF Air
I held the line on the Apple phone, won't own one. Still burns me because my Android Galaxy won't play well with the MacBook, so stuck with the proprietary issue again. :facepalm:
mhardy6647
Humo(u)r.
Apple and Sony use that same proprietary playbook which has angered me enough to steer clear of their products (as I type this on my 10 year old MacBook Pro) :confused:
You oughta see some of the 'pute hardware in use around here...
Well, maybe not. :cool:
Although, come to think of it, there is a Newton in the basement.
AudioX3
It's a set of thin wires. What possibly can a manufacturer or scientist do to make it better? What could the buyer be expecting? We all love food.... Could anyone fathom a, $100 box of pasta that would enhance your ziti to perfection?
theREALdotnet
TCD333
USB cables in short length deliver all the bits correctly. The ground connection though from the PC to DAC is an analog affair so in theory, some difference in noise can be there. If there is, and you can audibly hear something the solution is not another USB cable but to use better isolation (Toslink, XLR cables for interconnects, etc.). Measurements here show that there is no difference even in that department when with a "noisy" source like my desktop workstation PC.
WRT Grounding from PC to DAC, some DACs have full isolation, some don't.
The best implementation is a/ full galvanic isolation b/ clocking on DAC side of said isolation c/ Re-clocking after isolation as isolation adds a small amount of jitter.
I have no idea if any of the Topping / SMSL etc DAC's have full galv USB isolation but the above scheme is the best way to do it.
TCD
JSmith
Algol Perseus
galvanically isolated
If not, these do the job and aren't expensive;
JSmith
Extreme_Boky
Are you suggesting what I think you are suggesting?? You forgot the cups...
spigot
Just think how many Richard Clayderman records and concert tickets you could buy for a $1000... on second thoughts is it free postage?
AudioX3
Oh this is more fun than you could ever dream of.... Check out their website.... Jpslabs.Com. Start making your Christmas list.
voodooless
Netherlands
Why don’t you try responding to any of the actually decent questions that were directed at you? If you want a decent discussion, that’s the proper start.
RF Air
A Prime Mover reset for triggering? Is that the correct answer? :rolleyes:o_O
AudioSceptic
Northampton, UK
Oh come on guv'nor - I worked at a Linn/Naim dealership (itself a huge subjectivist minefield) and left the retail side retail in 2004!!!! That's nineteen years and almost a third of my life ago and believe me, the journey's been a rocky but enlightening one since and I ain't given up learning/unlearning more just yet!!! :D
All the sensible objective 'stuff' and realisations coalesced many years later when I DID do some unsighted comparisons and realised that level differences usually account for any perceived changes within reason. I do remember the odd occasion when I 'thought' I heard a difference and yet nothing was changed from A to B - other tales of the same thing told here, so I'm not alone in deeply un-trusting my ears, especially now with them as they are - the HD25SP on-ear headphones do seem to inject high frequencies better when I'm not wearing the hearing aids for some reason and they're still ok if 'lively' when I am, but that's a different subject :)
I mention the Linn Black interconnect as to itch a scratch I bought a used one recently to see if it really did appear to change the sound of the CD player I wanted to use it with :facepalm: level matched but sighted and A then B I could swear it appears to lighten the tone ever-so-slightly and emphases 'acoustic' a little more than the home made RG59 based cable I was using. Of course it's not scientific in any possible shape or form and on the face of it, these cables look to be straightforward screened coax types and nicely soldered up into the custom but basically competent generically sourced plugs which you can have customised with labels or whatever if you order enough. This well used cable does what I think I need it to do, but if anyone in the US has a set (unlikely to be any/many Linn electronics owners here though), perhaps Amir could give 'em a go.
It's a shame that it costs so much to send stuff over the pond, even something like a cable which doesn't need a huge amount of padding/protection. Perhaps there's some test we could do ourselves with REW, Audacity, or whatever? Perhaps Linn cables aren't that rare in the USA anyway? The LP12 is well known, of course, and the Linn phono preamps were favourably reviewed in Stereophile, so cables "to match" wouldn't be so unlikely, would they?
AudioSceptic
Northampton, UK
Same here, 10-yo MacBook Pro, bought as an Apple refurb so I saved a few £100. I'll do the same again when the time comes. But we digress...
DSJR
Suffolk Coastal, UK
I'm well out of all this now, but I'm sure a null test could show any real differences ;)
Got to say that these days, I use whatever I can find here of the right length. Any cable supporters would be stunned to 'hear' the Amazon Basics RCA cable if they didn't know what was in use (I remember someone who took his apart and was pleasantly surprised how the cable was put together as well as terminated).
AudioSceptic
Northampton, UK
I'm sure the Amazon cables are fine, but I've already got all the cables I'll ever need (Linn and QED) so won't need to buy any more. Yes, they cost more than they needed to, but I still had "that" doubt and the prices were quite reasonable (20-30 years ago). I never heard the differences claimed in What Hi-Fi and the rest, of course, just felt I was "playing safe".
