Is my amp enough for my speakers?
I am very new to Speaker amps so I am confused if that is enough headroom for the speaker to sound optimal.
It is less about the speaker sounding "optimal", since it is rated to handle 180 W, than how loudly you want to listen. The link I provided also has a comparison table, pasted below, that relates SPL to various real-world examples. I have actually been next to a newspaper press and it is not something you want to be near without ear protection. Given peaks may be 15~20 dB or so above your average level (headroom), your amp should provide an average level of around 80 dB with 20 dB headroom for peaks, which is very loud to me. I listen around 60 to 70 dB only rarely going louder. Based on that, and assuming you want to retain your hearing in the future, the 120 W/ch WiiM amp should be plenty loud enough. If you found an amp rated for 180 W, the max spec of the R3's, that would only provide a small (<2 dB) increase in volume so I think what you have now should be fine.
You have the gear, right? Does it play loud enough for you? If so, your good! Don’t worry and enjoy!
The amp is being shipped to me very soon so if the amp is not powerful enough i can get a full refund.
Thanks alot for the help and i will keep the amp then:)
I currently have the R3 meta with a Wiim Pro amp. Listening distance at 3 meters.
No problems with volume whatsoever, but I do use subwoofers with a crossover at 80 hz
I ended up switching back to the MiniDSP Flex due the the programming options. But the Wiim Amp Pro had plenty of power for the Kefs.
After much much listening back and forth, which is impossible to do blind, i do think the my Audiophonics NC252MP with a MiniDSP flex does sound better.
Why this is, no idea.
Get a basic SPL metering app for your phone and check your average listening level at your normal listening position...
allow circa 20db for headroom (that's quite a substantial safety margin)
I listen at around 72db - meaning 92db is my peak to allow for headroom - my setup is easily capable of well over 100db
Although my Wiim is in use in my sons bedroom, I did try it out on my main speakers (4ohm, with drops down to 1.6ohm) - and it handled them well and without concerns - with sound quality identical to the much more powerfull Crown XLS2500 amps I have there (440W@8ohm, 770W@4ohm).
The Wiim is a giant killer - and IMO more than capable of driving your Kef R3's, I would not be concerned about it.
