- Thread Starter
- #201
Decided to capture some of the work I have done with my lesser equipment. My main goal was to do an initial minimal crossover, but use it to compare the VituixCad (VC) model to what results were achieved. The VC model was pretty good but did not project the tweeter response accurately until I set the DSP option to be a miniDSP. Note I did not follow the usual minidsp instructions. Notably, I used minimal eq to get these results...
The main eq applied was to bass boost and boost the tweeter rolloff above 8 kHz. As planned, stuck to the 2.4 kHz LR2 crossover. The red plot is the result of my design. The blue trace shows reverse null when the tweeter polarity is reversed. As before, the measurements where taken at 75db, 1 meter, on-axis with a 3 ms gate (no smoothing).
The bass boost was about 6 dB at 100 Hz and a 30 Hz 2nd order HP filter was also applied (mainly to avoid exceeding the Purifi's excursion limits). In this alignment, the woofer is capable of over 100 dB of output at 40 Hz. My quick listening test revealed bass that was quite solid although my room has some serious modes at the speaker's location. With 2 speakers, I suspect the bass will be very pleasing for most music. I tried to keep port resonances tamed, but damping was not optimized and suspect it could be better. Will take some nearfield measurements and share tomorrow.
Please keep in mind this is all quite early in the Directiva development and expect much more refinement once I have a unit to send to Amir for a spin. I need at least one round with my upgraded equipment before I consider sending to him.
