Interior photos of hi-fi gear
  • Thread starter Thread starter Deleted member 2702
  • Start date Start date
D
Deleted member 2702
Guest
dCS Puccini U-clock. Price $4999 in 2009 (source), which is $7320 in 2024 when adjusting for inflation (calculator).
The interior photos are copied from here.
You could just about shove all that into an altoids tin.
OK cool thread. I like a good looking PCB and banks of output transisters like my fellow peeps and so here is one unit I have owned. I will space the letters so I do not have peeps searching the name and then coming here wanting me to repair or recap theirs.
K i n e r g e t i c s K B A - 7 5 in platinum green anodizing. Beautiful finish and a colored amp!
2480726-77b9bcb6-kinergetics-research-kba-75-platinum-pure-class-a-power-amplifier-one-off-completely-restored.jpg
This is a CD player. A Philips chassis, laser and PCB but the DAC section has been bypassed and a new section mounted above that PCB with dual DAC chips in the early 90s.
K i n e r g e t i c s K C D - 4 0
Inside my IRS2092 amplifier. I built the case myself from an old computer case and some random wood pieces I found in my dads basement. Awesome for driving a pair of subs!
And some random 2.1 TPA3116 amplifier board (with DSP!) I designed and 3D printed a case for. Perfect for my computer setup.
Unusual for sure. Keeping the power supply smoothing right by the outputs is a nice touch.
nice amplifier, too bad the last time I tried to turn it on it didn't start...sooner or later I'll have it repaired
Meridian 562 V3 with the controversial 517 Dac card as standard, which however in this model does not allow the device to be used as an analog preamp, because it does not control the volume.
