if the monitors are made to be wall mounted, then it's very possible (likely?) that the dsp for the forte would be sufficient.I see the (Bass Section) part of the ARC website blurb, but Anthem Room Correction's site talks all about room correction across the bands. Curious to know what the difference is.
Pretty set on the Arendal 1961 Monitors and 1S. That sub is damn good for the price and fits the formfactor I want for under my desk. The 1961 Monitors are made to be mounted on-wall. I'm going for a fully VESA wall-mounted setup with no stands or wires visible. They are incredibly low-profile and I like the way they look better than anything else. They also measure incredibly well.
Just looking for an amp/crossover recommendation.
regarding the sub, it may be good for the price, but, i prefer spending less and getting more... you may have to wait to find what you want, but it's worth it - imo, of course. things like this come up frequently, but you have to act quickly, because the good deals also go quickly:
https://www.usaudiomart.com/details...alex-acoustics-gramma-v2-isolation-platforms/
and if you don't want two, similar deals can be found for single subs, for even less $$$. of course, if you want the arendal sub, who am i to stop you?
re: the amp, the forte looks like a good deal for the $$$ at its closeout price. there's an infinite choice at that price range if you shop used, but you likely won't get bass management or the small form factor, and honestly, the choices are truly overwhelming; impossible for me (or most anyone, imo) to say "ya - xxx amp is killer at the price and will work great in this set-up, and with your listening preferences".
re: x-overs, i really like marchand, they're expensive, but compared to other hi-end offering they're a good deal. once in a great while you'll find a deal on a used iteration. so, i'd recommend a new or used dbx, something like this:
https://www.audiosavings.com/dbx-23...1FhuU8Ffac273XdppellVj6T_A2r76eRoC2V8QAvD_BwE
you don't really need anything with more options than a 2-way x-over, dbx also makes the 223 instead of the 234, but the unit i posted above is priced the same as what the 2-way goes for. these are really quite good units, and likely more than good enough for your desired use. in a super high end dedicated listening system, the marchand x-overs might be worth the added expense.
https://dbxpro.com/en/product_families/crossovers
doug s.
