- Thread Starter
- #21
Very interesting!From personal experience, I can recommend the Sabaj A30a. The sound is really good, the performance is good and the measured values should correspond to those of the VMV A2.
Also one of the few "real" digital amplifiers, so you don't have to worry about a DAC or a DAC upgrade. It has a built-in ADC for analog sources.
A friend recently brought his new WiiM amp to show me that I had spent far too much on "just" an amplifier. The next day he ordered a WiiM Pro and a Sabja A30a. The WiiM Amp isn't bad at all, from memory I would classify it as similar to a Fosi V3, but the better is the enemy of the good.
And before anyone shouts, when making such comparisons I adjust the volume, whether headphones or speakers, to 3 decimal places with a 1 kHz signal.
Since you took care to match the signals and really compare, what do you put the differences down to? Since more power is not supposed to bring more control or better sound (see above).
Do we know if the WiiM Ultra will have USB in (from computer)? The system will use computer sounds quite a bit and the USB to Optical to WiiM doesn't feel like a great solution honestly.
