Happened the same to me with my Onkyo RZ70 and last Dirac Version. Downloaded the 3.4.4 and no problems.Did anyone have issues exporting filter to the device when using Dirac on a PC? I took 11 measurements for my 12 speakers painfully and everything was calculated properly but dirac just sat there "preparing to export".
Mine is the latest version, after 132 sweeps.. saying that I was annoyed is an understatementHappened the same to me with my Onkyo RZ70 and last Dirac Version. Downloaded the 3.4.4 and no problems.
Regards!
I will try other versions and see, luckily I save the project always. However, I changed my sub settings slightly so that project is void nevertheless I can still use it for testing the export process.
Wow.. typically saved projects are some special jsons, csv, or some proprietary file format without any executables.. have you tried it? I will try soon with my older projects and see if I can at least load curves..I'm afraid saved projects only work with the software version the where messured and calculated...
Regards!
It’s out m8 … go check it outSoon, one can hope!
Oh wow, updating now!It’s out m8 … go check it out
Same! Been listening all day and it's been flawless. Frankly, this update moves the Integra into very rarified air in the AVR/AVP space. Good stuff!Woohoo! My entire house is Roon Ready, so this has been killing me...
Agreed! I'm anxiously anticipating a review from @amirm (or at least the Onkyo or Pioneer variant).Same! Been listening all day and it's been flawless. Frankly, this update moves the Integra into very rarified air in the AVR/AVP space. Good stuff!
Most likely won't measure up very well but that's alright.. I will be happy with a SINAD of 85db given all what DRX-8.4 has..Agreed! I'm anxiously anticipating a review from @amirm (or at least the Onkyo or Pioneer variant).
Awesome.. I don't use LCR internal amps at all..Also, as noted in the official thread over at AVS, they've also added a Pre-Amp mode for the front stage or all. I assume this is similar to D+M's amplifier disconnect, though we will have to experiment or wait for official details to be sure:
I see no reason why it can't achieve what the RZ50 does at the pre-outs: 97 dB. TheMost likely won't measure up very well but that's alright.. I will be happy with a SINAD of 85db given all what DRX-8.4 has..
If I remember right, the DRX8.4 has the ES9026pro, not the 9028pro. So, THD+N is -113 dB, still very good.I see no reason why it can't achieve what the RZ50 does at the pre-outs: 97 dB. The ES9028PRO DACs used in the DRX-8.4 are specced to 120 dB THD+N, after all. I suspect it would perform quite well measured in pure direct mode from the balanced pre-outs on Amir's test bench. Now, could you hear the difference? My old Denon X3700H V2 likely measured firmly in the 80s (same as X3800H) and it was transparent.
Yes you are right, thank you! I actually thought that -120 dB was high when I typed it, but I didn't double-check the model number.If I remember right, the DRX8.4 has the ES9026pro, not the 9028pro. So, THD+N is -113 dB, still very good.
