But does it Rock………..maninov?Musical schmusical - My amplifier is more Beethovenesque than Yours!
You love drumming and string quartets? How unusual!
Jim
You need to study and make your own recordings to verify that my statement ( and D. Floyd:s ) about the flawed stereosystem is correct.I don’t agree. Two channels is all we have with our ears. And that is all that is needed. Just get the two channels right and you are set.
Done right from recording to playback two channels will give you as much accuracy as anything else if not more.
Doing it right is the catch.
I have made my own recordings using the BACCH in ear microphones and compared the recordings to the original sound sources directly. They are almost indistinguishable. I suspect that neither you nor Dr. Floyd have done that. The proof is in that test.You need to study and make your own recordings to verify that my statement ( and D. Floyd:s ) about the flawed stereosystem is correct.
I see what you are saying and I understand. We are now in the realm of semantics.Edgar’s work is premised on the very thing you call an old canard. Two sound sources is all you need for two ears. And I think the results support the premise.
We are talking about two channel playback using two loudspeakers in a room, not using headphones.I have made my own recordings using the BACCH in ear microphones and compared the recordings to the original sound sources directly. They are almost indistinguishable. I suspect that neither you nor Dr. Floyd have done that. The proof is in that test.
I am also talking about two channel playback using two speakers in a room. The test works the room. It would probably work in a concert hall too but you wouldn’t be able to do direct comparisons. What’s best is subjective. What’s accurate is not. The test I did was for accuracy.We are talking about two channel playback using two loudspeakers in a room, not using headphones.
The best place to have the microphones in the concert hall is not the same place as the best listening position, far from it.
"Musical" is in no way equivalent to saturation. Saturation might be equivalent to boosted frequencies, but there is no direct scientifc analogy.I am curious as to whether there is an equivalent scientific musical term, which is the audio equivalent to colour "saturation" in photography?... Probably not.
In photography, pictorialism is the attempt to make photographs look like paintings by use of satin-matte surfaces and soft focus effects among other things. It is one alternative to “straight” photography that took advantage of a camera’s ability to render sharp detail."Musical" is in no way equivalent to saturation. Saturation might be equivalent to boosted frequencies, but there is no direct scientifc analogy.
The equivalent word in photography would be "Pictorial"
This camera is more pictorial than that one. And there we can see the nonsense.
Guitars are a string instruments...Adding bacon to sprouts is like adding a drummer to a string quartet.
XeroxicalIn photography, pictorialism is the attempt to make photographs look like paintings by use of satin-matte surfaces and soft focus effects among other things. It is one alternative to “straight” photography that took advantage of a camera’s ability to render sharp detail.
But photography is art, while audio playback is not, so the analogy fails.
One might as well argue that this copy machine makes copies of art works that are more artistic than that copy machine. It either makes copies that look like the original placed on the platen or not. If it does, then it would be equally good for pictorial and straight photographs. If it’s good for pictorial but not for straight photographs, that simply means that the effects (distortions) it introduces are harder to detect with pictorial originals.
I like the copy-machine analogy—nobody expects a copy machine to be “artistic” but some people do pay a lot for accuracy, in the full awareness that none of them are really accurate for reproducing art works. There is always generational loss, even when the print technology is identical to that which was used to create the original photograph.
So, when I say a system is musical, I mean a system with flaws that don’t audibly impair the listening experience compared with potential flaws another system might display. I’ve used that term with, for example, Advent loudspeakers, back when they were the affordable alternative to speakers with flabby oversized woofers with comparatively muddy or boomy bass response.
Rick “accuracy is better” Denney
Pianos are percussion instruments.Guitars are a string instruments...
And tomatoes are fruit.Guitars are a string instruments...
But are they legumes?So are beans aparently... And musical ones at that.
Always thought they were seeds myself.
Whodathunkit.
