Peng, I've read your posts for a long time and always admired the research and thoughtfulness that went into them, so am somewhat surprised by all the incorrect assumptions made about my comment:
1) I did get the info from the owner's manual
2) I did not misunderstand anything, or assume what was posted was max voltage. I simply posted I was concerned about the voltages as listed.
3) However since you brought up my "assumed" voltages and my "misunderstanding" of them, and then posted those assumed voltages are definitively NOT correct; please post what the output voltages actually are since you appear to know them.
There are quite a few AVR's that only put out unclipped 1-1.4V on unbalanced (my Yamaha being one), AND other devices tested here that could only manage 2V p-p unclipped on balanced connections (one of which I sent in for ASR testing). Note these are same low voltages that Integra lists for this device.
Hence the concern we might very well have a low preout device here as well, if their own documentation is any indication.
I wasn't sure, so I said "probably.......". Now that you have posted your questions, I went ahead and downloaded the instruction manual. My further comments are as below:
1) So, I assumed correctly on this one, you did get the info from the manual, thank you for confirming this.
2) My "
probably" covers the whole sentence. If you did get it from the manual, and is still concerned with the voltage, it would
seem that you
probably misunderstood what that part of the spec mean, sorry about making such an assumption. Regardless, I said so because no one (except the manufacturers, or those who research on them by contacting the right people) actually know what those pre out spec mean, I often cited the power consumption of AVRs as another example of those kind of specs that simply do not convey enough information, and often led to misunderstanding, or unnecessary concerns (or the opposite, such as being too optimistic in some cases) by their readers.
3) I used the 1-1.4 V as example based on what I have read from many owner's manuals and service manuals; and so I know the typical numbers are the likes of 1 V, 1.2 V (such as Yamaha, D+M, Onkyo), sometimes a little high, or even up to 2 V, or higher in rare cases. When I said they are obviously not correct, I referred to readers who
assumed those specified voltages are "maximum", otherwise I would not say they are incorrect, because they obvious are correct under the conditions they were measured, or designed for, by the manufactures. They just simply failed to tell us the detailed measured conditions, and/or under other conditions. I hope I made this point clear, if not, please kindly tell me and I will try to do a beter job explaining my point.
As far as what the output voltages actually are, I do not know. I don't know why you feel I "appear to know them". If I do, I would have mentioned the number. I am very frustrated with manufacturer specs such as this, the pre out voltage, power consumptions, power output spec, among others, that don't usually provide enough information for their potential customers to make their informed decision, without also rely on careful examination of bench measurement results such as ASR's.
Back to this specific example, I pasted Onkyo/Integra's specs on the pre out below:
They stated clearly, from the RCA output, the spec is 1 V/470 ohm for both the main zone and 1 V/2.2 kOhm for zone 2. The part that is not clear, is that it does not say anything about at what SINAD/THD+N that the 1 V/470 ohm was obtained, and what exactly does 1V/470 ohm mean, does it mean 1 V into a 470 ohm resistor? If so, would it then be 2 V/940 ohm, 4 V/1.88 kOhm (Ohm's law)? If I were to take an educated guess, I would say it
probably does mean the pre out can sustain 1 V driving into a load impedance of 470 ohm and it will be able to out higher voltages into higher load impedance, but how high? I really don't want to guess...
So, if you want to know the maximum voltage, you would have to either purchase the service manual, and hope there are enough information in it for us to determine the maximum voltage at an acceptable SINAD, or wait for one unit to get measured by a 3rd party such as Audioholics.com and/or Audiosciencereview.com, or get it from Onkyo/Integra.
Given the RZ50 was measured by ASR, and it did well on the 2 V test, I would say it is reasonable to
assume (just an assumption, based on educated guess) the Integra 8.4 can do the same, or even better. So, my guess would be: max 3.5 at 85 to 90 dB SINAD, a little higher, may be up to 4 V if you accept lower SINAD.
I hope this answers your questions, and please let me know if it doesn't, and I apologize for assuming you
probably have misunderstood the spec as "maximum", I should have worded it clearer.
