- Joined
- Feb 23, 2016
- Messages
- 20,852
- Likes
- 37,807
Maybe an area of life where lots of testing is blind.I have lots of personal data, some of it blind.
Actually, the alcohol does get into the inner ear, specifically into the endolymph of the inner ear's scala media (not shown in the diagram).
And conducting blind testing just requires a larger quantity than usual.That moisturizing is best done by ingesting the alcohol and having it delivered in the bloodstream.
That is the recommended procedure.That moisturizing is best done by ingesting the alcohol and having it delivered in the bloodstream.
Yeah, buddy, Doc.That is the recommended procedure.
That video brings up another issue with subjective reviews... in that they almost always conveniently forget application. Although this can be a factor in objective analysis as well. Say there's an amp that has lower noise to 50W but then it rises sharply, and another that's not as clean but maintains that level to 200W - if you have sensitive speakers and listen at low volume, the first should be subjectively better... but for a different application not nearly as good as the second one.
In the case of the cars... I doubt anyone would prefer (if offered for free) a busted rally car over an exotic supercar... unless their commute is through 2 feet of snow - then suddenly the former becomes the only viable choice.
So many subjective reviews would be less offensive if every statement were followed with the words "For me in my system" - but so often they instead use definitive statements which are seldom accurate and never universal. That's even before you consider that they're often talking about things that cannot be a universally definitive criteria at all (i.e. a 65 year old talking about the fantastic high frequency entension).
Why is so much time spent on this forum and others discussing and criticizing subjective reviewers?.
Then 98% of them die....Imagine if the energy of all these manufacturers and critics were turned towards more objective endeavors than bling and magic.
I all ready have a difficulty to comprehend the word Cognitive.Cognitive bias prevents us from perceiving perceptual bias.
"The term cognition comes from the Latin word cognoscere, which means knowing or knowing. Depending on the context, it can stand for knowledge, a belief, mind, the ability to learn, remember and exchange knowledge, and so on."
Exactly"A cognitive bias is a systematic pattern of deviation from norm or rationality in judgment. Individuals create their own "subjective reality" from their perception of the input. An individual's construction of reality, not the objective input, may dictate their behavior in the world. Thus, cognitive biases may sometimes lead to perceptual distortion, inaccurate judgment, illogical interpretation, or what is broadly called irrationality."
When it gets to the science of biology rather than physics one has to accept multiple tests and statistics, which is why nobody working on this sort of thing waited for, or tried to invent devices like thisI think the whole thing hinges on the fact that you can't know what a listener is really hearing, since all you have to go on is a description of the perceived sound quality by the listener. Now if there were a little jack on the back of our heads that we could connect to test instrumentation, or better yet, if we could connect ourselves up to someone else's ears and listen through them using those whimsical little jacks and the cable of choice, then maybe we could know for sure.
