Hey, I had a question actually. So, a balanced DAC outputs 4v. But an IEM needs only a few milliwatts at most. Shouldn't there be a device that takes the DAC output and steps it down for iems. Literally the opposite of an amplifier?@Ja1man The $13 Meizu HiFi has 95.8dB SNR @50mV:
So there's no need to spend any more if you're after the lowest possible noise floor. MoonRiver 2 and L&P W2 are noisier.
No longer in production unfortunately, so eBay etc is your best chance.wow. Did not know this. Will order it.
Here's why: https://www.audiosciencereview.com/...tive-to-the-meizu-hifi-pro.30802/post-1085671ASRs measurements are different
An attenuation adapter: https://diyaudioheaven.wordpress.com/headphones/headphone-attenuation-adapter/Shouldn't there be a device that takes the DAC output and steps it down for iems.
It's not the current King anymore. The new l30 Mark II has bested it by 5 SINAD.I only use IEMs. Since for IEM the metric that matters is 50mv performance I was comparing the dawn against the current king, the smsl sh8s (https://www.audiosciencereview.com/.../smsl-sh-8s-review-headphone-amplifier.22569/)
It sits at 95 at 50mv. Dawn is 93.8. So this is definitely the endgame from a "neutrality" perspective. Budding audiophiles can just buy this and know that their setup is clean for 16-bit audio.
He didn't reviewed the S9 PRO (ES9038Q2M), but the S9 (AK4493).see Amir’s video, it measures better than almost all other dongle dacs.
Hey @staticV3 seems you know your Meizu.No longer in production unfortunately, so eBay etc is your best chance.
The last one was sold for 11€:
Ahh ok, well I stand by my recommendation based off of Hidiz history of producing solid products.
Edit: Seeing your review, seems to be solid, I just wish it had a volume control. Did you run into any volume control issues? I occasionally have to reboot because I lose volume control.
TempoTec is OEM, Hidizs is/whose customer for line's of products.I'd also recommend the Tempotec Sonata HD, which appears to be a rebrand of the S8, with a slightly better performing DAC section but less powerful/less expensive option. I use it to drive my KSE1200s which come with an amp.
There are better options now with the same chipset. Moondrop Dawn for example.TempoTec is OEM, Hidizs is/whose customer for line's of products.
Among best measuring dongles if still not the best is Luxury&Precision W2 but that one is pricy.
Do you have mesurument & what's the price? Didn't sean that one.There are better options now with the same chipset. Moondrop Dawn for example.
https://www.l7audiolab.com/f/moondrop-dawn/Do you have mesurument & what's the price? Didn't sean that one.
Well not a bad price, neads a tap down in the volume from max. Good old CS43131 still dominate the ultra portable space.https://www.l7audiolab.com/f/moondrop-dawn/
https://www.l7audiolab.com/f/dawn-35edition/
Available with 3.5 and 4.4 out. Price is $65/70
Good performance as a DAC/Line out, but the Amp is rather meh.
I had a chance to remove the glass cover of my earmen eagle ( as i wanted to reglue it ) and the pcm board has Sparrow written on it so i think it might really be true. It sounds amazing paired with my Shures se535Heya Folks,
I have now tried a selection of dongle DAC's.
Ifi Hip DAC, Great power but constant hissing even on low sensitivity.
EarMen Eagle, Plenty of power but some distortion at higher output levels.
HiBy FC3, Limited power though DAC seems clear.
Non quite live up to expectations, or hype.
I have been looking at others like the Dragonfly Red or Cobalt that according to reviewers are SO much better.
Yet when I look at the reviews on this website they measure terribly.
Is there a decent measuring dongle DAC out there?
I am particularly looking for a dongle DAC for portability.
Funny thing about the EarMen Eagle. I noticed it glowed purple when I was listening to MQA on Tidal.... Yes I know please don't start... And the Eagle isn't ment to do MQA, as is the more expensive Sparrow. So I contacted EarMen and asked why this was and got back an email saying congratulations I was a lucky winner as the first 500 had the Pro chip from the EarMen Sparrow and I had one of them.
Still not sure if I'm having my chain yanked! How can I test this?
Thanks.
