- Thread Starter
- #61
My measurement setup:Just what dsp are you applying to the sub overall and with what?
REW -> laptop soundcard -> LPF -> amplifier -> passive sub -> UMIC-1 -> USB of the laptop -> REW
Can I analyze those sweeps with REW? Or maybe better borrow USB DAC...Use the chromecast as generator there are sweeps in tidal etc and redo the measurement
why strange? It's my home office. Normally I use the company laptop only for work and stream music via Chromecast.What a strange setup.
Why a lpf for a sealed sub for starters? Meant not the measurement setup, but your basic setup. Are you using REW to implement the lpf or ?why strange? It's my home office. Normally I use the company laptop only for work and stream music via Chromecast.
Ah, no, I've built a hardware LPF (resistors and capacitors, 3rd order) to cut everything after 40-60HzWhy a lpf for a sealed sub for starters? Meant not the measurement setup, but your basic setup. Are you using REW to implement the lpf or ?
Run RTA and enable show distortionCan I analyze those sweeps with REW? Or maybe better borrow USB DAC...
Why? Seems an electronic crossover with your speakers would be the better route.Ah, no, I've built a hardware LPF (resistors and capacitors, 3rd order) to cut everything after 40-60Hz
Maybe. We'll see. Just seems kinda goofy and not ideal to start with.In the OP’s defence though, he has found a solution that helps to understand where the problem might be occurring.
I doubt we would have gotten there digitally, if my premise of (digital) clipping is the cause.
So I think he is onto a decent path here.
ps nm to an extent, had hpf on the brain for the sealed sub. Still was more curious about specific hardware in the basic setup.
Yes, with speakers, sure. For just measurement of the build?If he didn't implement an LPF (analog or digital), it wouldn't be a sub.
Low pass filters filter out the high frequencies and let the low frequencies through.
Hi guys, mystery solved. Just got an external USB DAC to bypass audio out from my laptop:
REW-> USB DAC on ES9038PRO -> wideband amplifier (no LPF) -> passive sub -> UMIC-1 -> USB -> REW
Check out the curves. 3rd harmonic below 1%!!! and still without LPF.
