Help me convert old speakers to actives
Amp boxes will be attached once glued together
I am also thinking to put a neoprene sheet between the new front baffle and the old front panel.
If the idea is to provide some damping have a look at buytl sheet. It's often used in automotive panel damping with aluminium as the constraining layer.
It would be squeezed by screws. Would it slowly get squeezed out from between the panels? (There will be nothing to hold it in from the sides)
That'll only be a problem if you get one of the butyl sealant or putty varieties that feel a bit like chewing gum. The usual sheet forms (pond liner, gasket material) are stable like the varieties in vibration mounts, railway primary suspension etc.
I am about 60% through cabinet conversion/assembly. DSP setup after that.
Both the cabinet mods and the DSP setup are my very first attempts at these.
The new front baffles and back panels sanded and primed with shellac and sanded:
Remaining work:
- second (and maybe third) coat of paint
- soldering and attaching drivers to baffle and then to box
- internal lining of the MF chamber and routing the cables
- bolting on the back panel and amp
Hopefully setting up soon!
Real high amount of work so far, and it looks amazing. Respect!
Now the next step, the xovers.
Go ahead.
