Help me convert old speakers to actives
Take the barcode sticker off the P205.
The plan for the cabinet conversion is (using valchromat):
- add a new 18mm front baffle (this will block the port). Front baffle will have 1mm rubber gasket under it. Possbly angled bevels.
- add 8mm panels to all walls internally
- add 18mm internal partition LF/HF
- add internal bracing (3 or 4 braces)
- replace the 12mm back panel with 2x12mm new back panel, with the amp box in it. Back panel will be on threaded inserts and rubber gasket
- line internal walls with butyl or another (?)
- fill LF and MF chambers with wadding
This will make the internal volume for LF about 10L, which is suitable for the drivers. The MF volume will be about 3L, so room to add some more material/shape for more MF back absorption
Well, from the outside the speakers will look very similar. It is the inside and the back where all the changes will be.
Currently buying all the small bits needed (screws, gaskets, deadening etc.) and waiting for the guy who helps me with the woodwork to become available.
The trickiest bit on the cabinet will be patching the old front panel and bevelling the new baffle.
Hope to place the Valchromat order today.
- add a new 18mm front baffle (this will block the port). Front baffle will have 1mm rubber gasket under it. Possibly angled bevels.
Updated final build plan:
- add a new 18mm 19mm front baffle (this will block the port). Front baffle will have 1mm rubber gasket under it. Possibly angled bevels.
- add 18mm 19mm internal partition LF/HF
- add internal bracing (3-4 6 braces)
- replace the 12mm back panel with 2x12mm 12mm+19mm new back panel, with the amp box in it. Back panel will be on threaded inserts and rubber gasket
- line internal walls of the MF chamber with butyl 4mm and acoustic foam 50mm
The Valchromat order is pre-cut. Some pieces (that do not depend on other pieces) to exact size, some pieces to be trimmed once measured in place.
All materials have been delivered, hope to start the build next week.
It was PartsExpress, while I was in US on holiday
Price quoted in UK was 200GBP/driver.
I got them in US for under 80GBP/driver.
Tweeter and mid ordered in UK from lean business audio.
Two days of cutting and routing and the woodwork stage is compete - moving to the Ikea stage. The underestimation of woodwork time turned out to be by a factor of 3!
From this experience, modifying the cabinet (vs building a new one) is counterproductive. Building a new one should be easier and quicker, and would remove a few unnecessary constraints. And it is still an option to build a new one as a potential continuation of this project.
Somewhere on this panel there will be LED status indicator and IR sensor. Where do you think they best fit looks wise?
The two are a few mm apart, so really small, so I think would even fit under the bottom driver on the centreline.
