Many AVRs have pre outs. Even the middle range and many generations old Denon 3300 AVR had them. Switch the inbuilt amplifiers and you have an AVP.AVP: only really expensive choices there
AVR: not a nice fit with active speakers
Yes they basically have everything in a big ugly box that heats up, consumes electricity, has a ton of bugs, and measures badly. And then half of the box content is power amps, which I don’t need, nor want. If I were to forecast the future, the AVPs/AVRs die first.Many AVRs have pre outs. Even the middle range and many generations old Denon 3300 AVR had them. Switch the inbuilt amplifiers and you have an AVP.
It is your choice not to like them but you may have to keep waiting... there is no other type of device on the market that can decode surround and outputs multi-channel audio.Yes they basically have everything in a big ugly box that heats up, consumes electricity, has a ton of bugs, and measures badly. And then half of the box content is power amps, which I don’t need, nor want. If I were to forecast the future, the AVPs/AVRs die first.
I don’t need multichannel. All I want is strereo (or 2.1) with things like:It is your choice not to like them but you may have to keep waiting... there is no other type of device on the market that can decode surround and outputs multi-channel audio.
The thread is about HDMI input and your comment was on AVR/AVP. As both are multi-channel I was confused.I don’t need multichannel. All I want is strereo (or 2.1) with things like:
- xlr output
- earc input
Think any dac measured here with earc.
look up the thread what I will gain with that.
I know I have to wait. Thus I am running an AVP from 2007ish.
Or from strictly a speaker point of view just two speakers and a sub, altho bass management would be nice. What 2.1 content is there at all?But 2.1 output is multichannel, and 2.1 content is quite unusual.
As far as I know and understand 2.1 is the output from a stereo processor. The source is stereo.What 2.1 content is there at all?
Just wondering if there had been any efforts to do a 2.1 audio format, i.e. with an LFE channel. None I can think of.....As far as I know and understand 2.1 is the output from a stereo processor. The source is stereo.
There is no need as stereo a music format, whereas LFE is the effect channel of a film soundtrack.Just wondering if there had been any efforts to do a 2.1 audio format, i.e. with an LFE channel. None I can think of.....
It can be used for music, usually isn't even in surround formats for music, tho. Music doesn't necessarily mean 2ch stereo either.There is no need as stereo a music format, whereas LFE is the effect channel of a film soundtrack.
I was talking about stereo as the sub thread is about 2.1.It can be used for music, usually isn't even in surround formats for music, tho. Music doesn't necessarily mean 2ch stereo either.
So you only want to listen to a down-mix where often LFE and surround channels are omitted?The usability gains, e.g. my daughter can pick Apple TV remote and press power button. This turns on my UST projector (it already works both on/off). It should turn my DAC on too (which doesn’t work), which in turn turns my active speakers on (works already with master slave power cord where dac is master). If DAC had eARC this would work. Lip sync would be perfect, and I possibly could get over 48 kHz/24bit soundtrack too (uncompressed). Similarly when she stops, she can push the power button and thats it. Also volume control/mute works directly from Apple TV remote (this I can get to work with Apple TV as it can learn ir codes). It is first world problem, but there is solution, and that is eARC.
That is what I am fine with it. If that .1 could be added, even better. Surrounds and height channels can be omitted, let’s say my maximum is 3.2, but I am fine if manufacturers start to solve this with 2.0.So you only want to listen to a down-mix where often LFE and surround channels are omitted?
Odd to want to listen only part of the sound track but I respect your choice.That is what I am fine with it.
Didn’t you just say downmix channels, or whatever there is in stereo mix. Don’t some LFE data get there already? And why would I want surround and height channels, if I don’t even have those speakers? I think most that adds to movie soundtrack outside stereo is LFE and center (which I don’t believe these stereo DAC start to support soon, turning them 3.1 mch DACs). For music the stereo contains it all (yes, cutting some corners here).Odd to want to listen only part of the sound track but I respect your choice.
