Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 5,241
- Likes
- 5,480
Thanks, I finally get to use the "ignore" button for the first timePot calling kettle…
Will you be able to play/use the 8361 with GLM?There is a chance I will hear them side by side early Jan depending on how we go with covid in Oz
Butting in late here, but the 801 and M801 were rather different to the N series and the Matrix carcass really did subtly improve on the original (a pal was given the 801's he used for mastering when B&W replaced them with the 'M' version and still has them in his home theatre system). I heard an early pair of N801's and disliked them intensely.No such thing as an 800 precursor to 801, AFAIK
Show me on this B&W published response of the original 801:-
I don't see it.
cheers
Yes friend . You would never do it any other way . I had plenty of GLM experience with my 8341's prior to selling.Will you be able to play/use the 8361 with GLM?
Because that ultimately has a large influence on how the speaker sounds.
As others have stated, from 300hz on down. GLM doesn’t appear to do anything above 300hz which is why some of us are running Dirac on top of GLM.Will you be able to play/use the 8361 with GLM?
I don't understand - Are you saying GLM is limited to below 300Hz?As others have stated, from 300hz on down. GLM doesn’t appear to do anything above 300hz which is why some of us are running Dirac on top of GLM.
Also, you can individually adjust so called "sound character profiles" (low and high shelves) and set individual filters up to 21Khz to your taste or requirements. So, you are far from limited to up to 300Hz with GLM.
And indeed, as far as that, ultimately it can have a large influence on how the speaker sound in the end.
Btw: I runned REW and Dirac after GLM.
Actually, with me, Dirac with Audirvana plug-in is always a pain to use as it always crashes before ending all the sweeps...
REW calculated further EQ which I could have integrated directly into GLM filters and saved in the speakers.
I preferred to first implemented them into my RME ADI dac, so I can easily pull them out or adapt/test them.
All I can say is that the speakers now sound very different to my ears in my untreated room as from straight out of the box.
I have not run 4.1 yet. But my understanding is that 4.0 and below mainly affected 300 hz and below. That said, I could be wrong about this.On my 8330A it goes up to around 2K on GLM 4.1 but it appears that GLM mostly leaves higher frequencies alone.
Here is an older calibration using GLM 4.0 for left speaker, while the right has the highest "active" notch at 258Hz. When calibration with GLM I use a tight pattern of 8/9 measuring points around my MLP at the desk.
I added a screenshot of GLM 4.1 calibration in post #1427 where a shelving filter is added to my left speaker.Thanks for this. Although most of the correction is happening below 300, it is clearly doing some things above. I will need to look at my measurements more closely and see if I can determine what’s going on.
Since Genelec speakers are often very flat in their axial response above 300 Hz, it is undesirable for GLM to change it much, if at all. Genelec probably know this, hence what you are seeing.Although most of the correction is happening below 300, it is clearly doing some things above. I will need to look at my measurements more closely and see if I can determine what’s going on.
The image will then sit on the ground too. Tilting the speaker will not change this. This is unpleasant to my experience.Is there a downside to placing them 20cm above the floor pointing upwards instead of wall mounting, pointing downwards? Vertical isn't possible, sadly.
No it did appAs others have stated, from 300hz on down. GLM doesn’t appear to do anything above 300hz which is why some of us are running Dirac on top of GLM.
True but you can still have a lot of fun. BBC dip is easy .As others have stated, from 300hz on down. GLM doesn’t appear to do anything above 300hz which is why some of us are running Dirac on top of GLM.
From memory I think GLM may have put a small narrow reduction around 480hzNo it did app
No, you cannot influence the off-axis response separately from the on-axis. So you can’t do a perfect match.OK it may be a stupid question but still...
Theoretically is it possible to EQ the 8361 and make it sound like Focal or ATC?
