Questions for inquiry:
1. Does your room or cartridge temperature change? I recall that Lyra likes their cartridges to be in a 'warm' environment. Something to do with suspension 'rubber ' damper.
2. Cartridge age and dampers. Most of these cartridges are 'venerable.' Consider card suspension/tires? As far as I recall , the cartridges OPs mention are fairly old, for example, the Technics EPC-270cCii or Yamaha MC-5 even if they are NOS. Might have something to do with their rubber suspensions/dampers 'drying out'? Consider speaker surrounds they decrepitate with age.
3. Original specs - most of them are 25-28dB of separation. You're lucky to be still getting it with older cartridges. Maybe it is not the test records fault.
4. Does anyone have a 'new this year' cartridge to test?
Thanks for the questions. As best as I can tell this is what I think.
1. Have to ask
@mackat if there was something different with the measurement set-up. As far as mine go, as I wrote on the intro all my measurements are taken in temperature between 68-72 degrees F year round. But I have had consistent results in terms of crosstalk, never anything like the one outlier posted.
2. I don't understand how a dried out damper would result in both superlative crosstalk measurements for the Yamaha and the test record working better. At this point I think there is a lot of evidence in the FR that says if there is a suspension or damper issue. I'll post damper restoration measurements in the near future, though if you are interested now old versions of those measurements have been posted here somewhere.
3. Perhaps. And that often depends on how they were stored. But plenty of the ones posted here perform to spec. Certainly there are those Technics that fail, the Shure VN45MR stylus, and some A-T dampers that dry out but these are surprisingly very robust little things. I think the failure prone ones are become better known and reasons better understood. Also note that it is becoming more clear that many cartridges are underspec'ed because manufacturers were using the same test records we were at times. My Shure V15 V-MR measures at -35 dB crosstalk at 1kHz on a DIN 45 435 test record. Spec is -25+ dB. I get -30 dB on CA-TRS-1007.
4. Do you know what some of the new cartridges are? I have no idea what has come out this year. Perhaps Audio-Technica updates? If so there is likely information available regarding them.
