- Joined
- Mar 30, 2019
- Messages
- 1,297
- Likes
- 2,368
Oh I misread it. I thought it was scaled in some way. Didn't realize 0.5 was actually 0.5.Not sure what you mean. Can’t see 50 Hz in your spectrogram.
You have 6 and 9 Hz peaks. Change to 0.1 % scale to see more clearly.Oh I misread it. I thought it was scaled in some way. Didn't realize 0.5 was actually 0.5.
Will try to set it up better and update. Are those peaks usually indicative of anything in particular? Issues dealing more with flutter? Or tonearm bearing or simply cartridge resonance?You have 6 and 9 Hz peaks. Change to 0.1 % scale to see more clearly.
No expert on direct drives. If you have another test record you can see whether the same peaks arise. If so there is probably something with the drive mechanism. Tomorrow I will make some more tests with my new more heavy platter for my BD Linn Axis. It should reduce belt-platter resonance frequency and Q.Will try to set it up better and update. Are those peaks usually indicative of anything in particular? Issues dealing more with flutter? Or tonearm bearing or simply cartridge resonance?
Which test record is this?Didn't use the microscope so it could still be a bit better. I have to admit that it is easier to adjust and check placement with this program than with WFGUI. Looking forward to testing this with my Denon DP-30L II.
View attachment 313225View attachment 313227View attachment 313224View attachment 313229
Oh yeah, a new copy of Tacet Vinyl Check. Bought from Amazon a few months ago. It was the first one I found in years that seems close to my old "good" copy (i.e. with only a centering issue). I must have returned near 15 copies as they all had pressing issues. It seems that new stock is better. I haven't run extensive tests on it with Scott and JP's script and with my Denon DP-30L II so we will see. But if these results are worst case scenario, they seem reasonable for the old Sony PS-X50.Which test record is this?
If it helps, my Tacet results are similar in that it takes a few seconds to stabilize with the program.So today I made some measurements of my "new" Linn Axis.
First, I have changed the motor pulley to an LP12 motor pulley since the old one was a bit wobbly.
Second, I have managed to get a spare LP12 outer platter. This one weighs 2500 g as opposed to the aluminum variant of the Axis at 1025-1050 g. The inner platter weights 500 g. Since the outer platter brings more to the inertia, I would expect some more stability and lower resonance of the belt-platter.
The polar plot looks a bit better than my previous results of the lighter Axis platter. This is from the Tacet record 3150 signal, 10 seconds into the file.
And the output of the T100 analyser shows lower spectral components as well. It is mainly 1.1 and 2.2 Hz, and some peaks which falls near the resonance frequency of the cartridge-arm.
There are some strange readings though. In the beginning of the reading, the values are quite high, as seen with data taken from the logger, taking 1 second slices It does not stabilise until 10 seconds of the 3150 Hz file. Not sure what this is - (i) resonance induced after sudden increase of friction, (II) something with the Tacet record.
The values stabilise at around 0.024% WRMS and 0.039% Quasi-peak, but are way higher the first seconds:
View attachment 313329View attachment 313332
Also seen with the T100 analyser with an "early" image grab, but I cannot see any resonant frequency besides the usual record-related ones:
,View attachment 313335
A question:
What is the time-window used for calculation of Quasi-Peak? I thought it was 1 second? For WRMS it is 5 seconds according to what I've read.
Ok so you also see the same thing? Is it possible for you to log the values (I start the logging directly after the signal starts) and publish? I want to know if this is a software/record thing/ or something with the turntable.If it helps, my Tacet results are similar in that it takes a few seconds to stabilize with the program.
It's looking like you did a really good job with the turntable.
I am not sure. It is a belt drive so I guess I will see losses and variations. It will never approach a direct drive. At least it is measurably better than before. Listening to Joni Mitchell "Blue" as I write and it sounds really fine.Looks like filter settling. I'd imagine you could just start the signal at the latter point where the track measures good and see if you get the same behavior.
The polar looks really good except the portion I've marked here. Is that in the record, or is it a bearing issue?
(I never thought I would do anything more investments on the turntable than exchange stylii, but these new measurement tools got me interested again.. There are new (expensive) bearings to buy as well...but I checked the one I have and it seems really fine.So now I will just play music. )
Yes, I could. I might do some more; however I have got other toys (E1DA Scaler arrived...) and perhaps to restore my old Linn Akito tonearm with new bearings. Don't know what to do with it though; but I once had a plan to make a bigger foundation for my Axis and have two tonearms. I have the Axis look-alike "Brinkman Avance" in mind, but just a bit bigger. Time flies.You can 'index' the test record off the tone start. From there, just rotate the record 180° and see if the blip follow the record or the platter.
View attachment 313398![]()
Yes, sometimes you hit the record limit; still some 0.55 Hz signal left. Widening the hole is the only solution then. Otherwise the usual 1.1, 2.2 and probably also 3.3 Hz that is record-pressing related. Consistency is excellent as would be expected from the Denon.I think I hit my limit with this Tacet record in terms of non-microscope set-up. I may even have to widen the hole to come close to center. My push-in every side method essentially yields the same results as the Sony above. But the 0.04% is with the record completely off-center.
View attachment 313413View attachment 313414
I am getting a similar "indentation."
I will update measurements of my Muffsy preamp tomorrow. Need a scaler for impedance matchning...Hey, my Scaler arrived last week! Let me know if you come across any interesting uses or results.
www.audiosciencereview.com
Did you also see the initial higher W&F in the beginning of the sweep with the Denon (and stabilisation after a few seconds)?
