ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 5,721
- Likes
- 3,420
Ok about smartphone's ability to fully power dongles, although in my opinion if we are talking about max power achievable with a dongle, it has to be referred to a fully capable power source, not a phone.@mc.god FiiO's dongle DAC of course. Phone's won't give 0.5A 5V but 0.2~0.3, it can be increased in ROM regarding costume Android. 0.5 is USB 2.0 limit, 3.0 can go to 0.9 but sadly isn't used at all even USB audio 3.0 specification is finalised several years ago.
Since again, K11 is a desktop device, while, if you intended KA11 dongle, as it seems the case, it is only SE and specs are rather different.K11 is rather bad design with 2V 65 mW unbalanced out and 104.5 dB SINAD and 4V balanced out with SINAD of 97 dB.
It's line level for sure, they changed it in the long description text to have a bit of separation by saying "2 Vrms Max" and not follow it directly with @32 but put a different thing in the parenthesis, i.e. "(125 mW @32 ohms)". Here the 125 is probably a copy-paste mistake because they have the same exact SE spec for the TP30 which has additional amplification. So for the TP20 it was probably supposed to read something like "75 mW @32 ohms" (half of their TP20 BAL spec), and in this form it's not quite the same as saying that the 2 Vrms is achieved AT 32 ohms.Again, don't trust too much that advertised specs since often they are so badly translated that you end up with an headache trying to sort them out.
I can't give it for sure but I don't trust at all that 2V@32ohm, i bet they intend 2V at line level as always, and 125mW are more likely combined also in this case.
ahaha, what a nightmare, kudos to you for actively trying to make them correct but i think it's a Don Quijote fight given the linguistic difference, translation problems and more or less explicit attempt to allure less informed customers.It's line level for sure, they changed it in the long description text to have a bit of separation by saying "2 Vrms Max" and not follow it directly with @32 but put a different thing in the parenthesis, i.e. "(125 mW @32 ohms)". Here the 125 is probably a copy-paste mistake because they have the same exact SE spec for the TP30 which has additional amplification. So for the TP20 it was probably supposed to read something like "75 mW @32 ohms" (half of their TP20 BAL spec), and in this form it's not quite the same as saying that the 2 Vrms is achieved AT 32 ohms.
They changed this after I got in their DMs to pester them about their "4 Vrms @32 ohms" spec for the TP30 being half a watt and practically impossible LMAO. But no matter how much I tried to clarify they just didn't want put in a clearer separation between the Vrms and the @32 ohms. Or maybe they just didn't want to provide an exact impedance where the 2 Vrms and 4 Vrms were achieved exactly, so it wouldn't affect their marketing.
Then they also had "Output impedance: 32 ohms" and I got them to change that as well, but they didn't agree to simply delete it OR to get the real number from the engineering department, so they just put in another parenthesis to explain how they got that number, i.e. it was only talking about how their max-power tests were done with a 32 ohm load.![]()
translation:
Last addition about Tempotec Sonata BHD (non Pro), i found some measurements taken with RMAA in a youtube video review. I don't know the quality of ADC used since the review is in Russian language so out of my understanding, but graphs are graphs and RMAA summary report has a known series of results, so we have:
View attachment 377920 View attachment 377921 translation: View attachment 377913
View attachment 377922View attachment 377923View attachment 377924View attachment 377925View attachment 377926
So it is confirmed to be pretty solid and a very good choice when on sale.
Yes, crosstalk rejection of 3.5 out seems not very good at -60 dB where most other dongles he reviewed got > -75 dB.I've noticed that stereo crosstalk is much worse than on other CS43131 reviewed by this user, how much would you say it can be noticeable in real content?
Only issue with the MAX97220 chip is that it raises the output impedance to 2Ohms over the standalone CX31993 0.5 Ohm. Other than that it's a great cost effective option with more power than Apple dongle.JCALLY JM6 PRO measurements
Here's another one from a brand with a good reputation here. From my understanding the "pro" in the name comes from the use of the MAX97220 chip that affords it more power than the standalone CX31993 dongles have. I measured the voltage at max output and it is 1.455V.
The measurement chain is as follows: Windows PC - Topping HS02 isolator - JCALLY JM6 PRO - E1DA Scaler/Cosmos.
Please note that the output was set to 24/48. The RMAA measurements are of the left channel taken with the Cosmos in mono mode as it performs better that way. They are supplemented by the stereo crosstalk results.
View attachment 378258View attachment 378241
View attachment 378251View attachment 378252
View attachment 378253View attachment 378254
View attachment 378255View attachment 378256
Do note I am now going to use the AES17-2015 standard notch setting for distortion results on REW. The first measurement was posted so that it can be compared apples to apples with my previous ones. The difference is only a dB here but I prefer to be upfront about these things.
SINAD of about 96.8 dB, which meets spec. In all this gets the job done. The 1kHz sine shows a wide skirt with some hash, but it should be inaudible. These are workman-like results that are good for the price and product position, but less so each passing day. To be sure, the JM-20 is the one to get, but anyone that has this and is happy should remain so.
I am hoping to build my own custom alligator clip cable so that I can use my E1DA loading board in order to take measurements at specific loads. But I am guessing this performs well enough for IEMs and more efficient headphones.
Should be fine.Hey everyone, first post here.
CS43131 seems to be favourable - does anyone know if it works properly with Google Pixel 8 phones or where to find compatibility information, please?
All the best,
Dax.
This lists JCally AP10 and iBasso DC04PRO among tested DACs that work, which uses CS43131 Maybe order with a return policy if it's a different CS43131 DAC.Thanks @markanini. I've seen a bunch of (older) threads saying that P8 and P8P don't play well with UAP2.0 USB dongles so I was hoping to get a definitive yes/no.
TTGK Technology Co.,Ltd CX31993 384Khz HIFI AUDIO at usb-0000:00:1d.0-1.1.1.1, : USB Audio
Playback:
Status: Stop
Interface 1
Altset 1
Format: S16_LE
Channels: 2
Endpoint: 0x01 (1 OUT) (SYNC)
Rates: 8000, 16000, 32000, 44100, 48000, 96000
Bits: 16
Channel map: FL FR
Interface 1
Altset 2
Format: S24_3LE
Channels: 2
Bits: 24
Channel map: FL FR
Interface 1
Altset 3
Format: S32_LE
Channels: 2
Bits: 32
Channel map: FL FR
Capture:
Status: Stop
Interface 2
Altset 1
Format: S16_LE
Channels: 1
Endpoint: 0x81 (1 IN) (SYNC)
Bits: 16
Channel map: FL
Interface 2
Altset 2
Format: S24_3LE
Channels: 1
Bits: 24
Channel map: FL
I bought it just for a nice to have gadget to leave at my office pc but honestly with my iems and headphones i could perfectly live with this alone, €5.50 (thin metal case and usb-c\usb-a adapter included) and dac\amp resolved, jaw dropping
I just plugged it to my phone and playing via UAPP, made some steps around my house, moved and rotated the phone in my hand in all ways and directions, nothing happened.Interested to see if you have the issue I do moving around. If you have the chance to try of course. Good to know it works on linux as I have not plugged it into the PC yet.
