Novice, Digitizing Vinyl & 78s - Seeking Equipment Recommendations
scholarly-donut
Hello,
I am currently in the process of digitizing a lot of older (1950's & earlier) media to archive online. We are starting with vinyl (33 1/3 & 45) and 78s.
We do not have any record players that are capable of playing 78s currently, so we were looking to buy a 3-speed turntable with a detachable cartridge/stylus. This turntable was recommended on an old Reddit post on 78 turntables, so we were wondering if anyone could vouch for this turntable or perhaps recommend a better one.
In terms of pre-amps and A/Ds, we have a Radial J33 Phono Preamp & DI and a Solid State Logic 2-in/2-out USB audio interface. Is there one that is better than the other/more suitable for recording the audio of a vinyl/78 and converting it to a digital format on a laptop/computer?
As someone who has never digitized these kind of materials before, I'm not really sure where to start. I can provide more information if necessary.
Thanks.
Here’s ChatGPT response:
Digitizing your vinyl record collection can be a rewarding project that preserves your music in a convenient digital format. Here are some tips and recommendations for both hardware and software to help you get started:
### Hardware
1. **Turntable**:
- Ensure you have a high-quality turntable with a good cartridge and needle. For 78rpm records, you might need a turntable that supports 78rpm playback and possibly a special stylus designed for 78rpm grooves.
- **Recommended Turntables**:
- Audio-Technica AT-LP120XUSB (supports 33-1/3, 45, and 78rpm)
- Fluance RT82 (requires an additional preamp)
2. **Preamp**:
- A preamp is essential to boost the signal from the turntable to a level suitable for recording. Some turntables have built-in preamps.
- **Recommended Preamps**:
- Art DJPRE II Phono Preamp
- Pro-Ject Phono Box MM
3. **Audio Interface**:
- If your turntable or preamp does not have a USB output, you'll need an audio interface to connect to your computer.
- **Recommended Audio Interfaces**:
- Focusrite Scarlett 2i2
- Behringer UMC22
4. **Cables**:
- Ensure you have quality RCA cables and USB cables to connect all your components.
### Software
1. **Audacity**:
- A free, open-source audio recording and editing software. It’s user-friendly and widely used for digitizing vinyl records.
- Features include noise reduction, click/pop removal, and various audio effects.
2. **VinylStudio**:
- A dedicated program for digitizing vinyl and cassette tapes. It offers advanced features for track splitting, album cover lookup, and more.
- Available for both Windows and Mac.
3. **Pure Vinyl**:
- For Mac users, this software provides a comprehensive solution for vinyl recording, with features like high-quality RIAA equalization, click/pop removal, and more.
### Steps for Digitizing Your Vinyl
1. **Setup**:
- Connect your turntable to the preamp (if needed), then connect the preamp to your audio interface, and finally connect the audio interface to your computer.
- Install and configure your chosen software.
2. **Recording**:
- Clean your records to minimize noise.
- Set the correct speed (33-1/3 or 78rpm) on your turntable.
- Start recording in your software. Record the entire side of the album without stopping.
- Repeat for each side of the records.
3. **Post-Processing**:
- Use software tools to remove clicks, pops, and other noise.
- Normalize the audio to ensure consistent volume levels.
- Split the recording into individual tracks.
- Add metadata such as artist, album, track names, and album artwork.
4. **Exporting**:
- Export your tracks to your preferred format (e.g., MP3, FLAC, WAV).
- Organize your digital library on your computer.
### Additional Tips
- **Backup your digital files**: Store copies on external drives or cloud storage to prevent data loss.
- **Regular maintenance**: Clean your turntable and stylus regularly to ensure the best sound quality.
- **Experiment with settings**: Different records may require adjustments in recording levels or software settings for optimal results.
By following these guidelines and using the recommended tools, you can successfully digitize your record collection while preserving the quality and integrity of your music.
,we were looking to buy a 3-speed turntable with a detachable cartridge/stylus.
So, I guess you know that 78's need a different stylus. The easiest thing is to have a 2nd cartridge & headshell with a 78 stylus that you can swap-in.
If I were buying a turntable, that's probably the one I'd buy. It's got a built-in preamp (which you can bypass if you already have one that you want to use), it's got USB for digitizing, and it's direct drive so there are no belts or rubber drive wheels to wear out. It also comes ready-to-play with a cartridge, whereas with "traditional" turntables, the cartridge has to be purchased separately. And IMO, it's not "too cheap" or "crazy expensive".
You don't need that with a USB turntable. ;) A potential advantage with the audio interface is that it has a recording level, whereas the turntable's USB output is not adjustable. But digital recording levels aren't critical as long as you are not clipping. If you remember analog tape you wanted a hot signal to overcome tape noise, but it's not an issue with digital and there is no quality loss if you amplify after digitizing. Tape was more forgiving on the loud side and if you occasionally went "into the red" it would soft-clip. Digital is hard-limited to 0dB and it will hard-clip if you try to go over.
The equalization curves are different for 78's than LPs. The standard RIAA equalization curve didn't exist yet so there was no one-standard. You'll need to EQ for the difference between the RIAA EQ and 78 EQ. Then, you'll probably want to EQ a bit more by-ear. Or, maybe just do the whole thing by-ear.
Here is something I found about 78 equalization.
BTW - If you play at 45 (or 33) RPM and speed it up digitally, that further fouls-up the EQ so it is better to get a 78 RPM player.
This page has tons of information about digitizing and cleaning-up the digitized copy. It hasn't been updated in almost 2 decades (!) so although most of the information still applies, some of the software may no longer exist and I'm sure some of the links are dead.
The author of that page is the developer of Wave Repair ($30 USD) which is a tool for fixing-up clicks & pops. It does a great job on most (but not all) clicks & pops, but it's manual and it's VERY time consuming. On the upside, it only "touches" the audio where you identify a defect. It has a few repair modes, including one that copies from the good channel to the bad channel. (Usually the defect is only in one channel, or sometimes the left & right clicks are a bit offset in time.) With stereo records you don't usually notice the loss of stereo for a few milliseconds, and it's "perfect" for mono 78's. I have another totally automatic (and free) de-clicker called Wave Corrector. Audacity also a couple of "clean-up" tools built-in.
I've transferred a lot of 78s. It might seem counterintuitive, but old Garrard or BSR turntables with flip over ceramic cartridges supply a line-level signal without the RIAA EQ. RIAA is for LPs, 78s had a lot of different eq adjustments. I'd take the signal from the turntable, record via a handheld digital recorder and make adjustments with Audacity. I used Click Repair to reduce clicks and pops. However, in the past I found that recording into a cassette deck both reduced the level of clicks and pops and cut the surface noise.
Possibly analog frequency response of cassette decks with soft clipping that reduces audio spikes (clicks and pops) too. Or so I've been told. What do others think?
There's also the way tape (all analog tape) saturates first in the high frequencies. I've had as good luck without Dolby as with. The background hiss level doesn't matter all that much with 78 sources.
Forgot to mention this, but Click Repair also helped with 78 and LP sources.
Thank you for all the advice! Do you have any specific brands/types of cartridges/headshells/stylus you recommend, or are there any specific models I need to get for that specific turntable?
If you're getting the recommended Audio Technica turntable the built-in cartridge is the Audio-Technica AT-VM95E. The VMN95SP is the stylus for that cartridge that is designed to play back 78s. Again, I prefer ceramic cartridges as phono preamps (including the one that's part of that AT turntable) use RIAA, which would make the 78s sound both boomy and dull. However, the Audio Technica VM-95 series is an excellent moving magnet platform for a wide variety of styli. Recording in 24 bits, allowing for a lot of headroom, makes extreme eq adjustments possible.
I have been digitizing all of my 45s.
Here is my setup:
Cheap Turntable I salvaged from eBay
ART USB Phono Plus bought used from eBay
Laptop with Audacity
I have been using the built in Audacity click remover and then exporting to mp3 format and saving on my home network.
I also loaded everything up on an old Android phone for use in the car.
The nice thing about the ART device is that it has a toggle for phono / line. So it works with either type of signal. I am very happy with it.
These look more than fine.
Some more tips:
Take note of the channel balance of your cartridges and correct relative levels (pan) accordingly.
On a mono record, simply summing L and R to mono generally works decently, however something like the Voice Cut Filter DSP for Foobar2000 (foo_dsp_centercut) tends to be substantially more effective in reducing L-R noise, turning a crackly old record into perfectly quiet affair. A 64-bit version is available. Audacity comes with a vocal reduction and isolation effect, I couldn't tell you offhand whether that's as good. (My focus at the time was more on cleaning up a lossy stereo rip at playback, which was all I had of this super obscure record.)
I am getting great results using the following:
Turntable ==> Parks Audio Puffin ==> SPIDF out ==> SPIDF to TOSLINK converter ==> TOSLINK cable with mini TOSLINK adapter ==> Mac mini built-in sound input
Recording using Audacity or Adobe Audition ==> output to AIIF/WAV/m4a/FLAC.
I'm using the ATVM95N cartridge but I want to see how it sounds with other needles. If you're interested in hearing a sample try this link...
I ended up with the Audient Evo 4 for vinyl rips because of three features: digital gain, L/R gain linking, Smartgain. See the video below for demo of Smartgain and general review of the interface, I personally love it for this use case.
I like Acon Digital Acoustica for processing, it has the best de-click / de-crackle out there from my brief testing and otherwise is a very capable and well designed processor. You only need the cheapest standard edition, which is fantastic value for money.
My setup is:
  • Technics SL-1210MK2 + AT-VM95ML cartridge
  • NAD PP2e pre
  • Evo 4
My process is:
  • rip 24/48
  • de-crackle
  • normalise to EBU R 128 (-16 LUFS to match Apple Music Sound Check)
  • save acoustica project workspace and export processed file
  • batch convert processed files to AAC 256 using Fission app and import into Apple Music app
  • do quick tagging from Discogs api using Meta app
  • sometimes do deeper tagging using data pulled from various APIs using MP3TAG
This works for me since I only rip and save individual songs not whole sides / albums. For an album centric workflow VinylStudio is worth a look although I found it overkill for my needs.
I don't know how necessary something like SmartGain really is for ripping vinyl on an interface with a 113 dB(A) input dynamic range... you might need about 90 tops for the format, and that's with a following wind. You should be able to just ballpark the gain and leave it at that and do the rest in post... if you have any hot 12" EPs from the DJ realm, have those peak at -6 dBFS or so and you should be golden.
If you bought the EVO 4 longer than a year or so back, it may still have the AKM AK5552 ADC (newer models have gone to the ESS ES9820). That doesn't exactly have the greatest digital filter known to man, and I would recommend going 24/96. If you're not sure what you have, you should be able to take a loopback measurement and observe the amount of passband ripple. If what you get looks like Julian's result, it's the AKM, while if it's pretty much flat and smooth and zoomed in, it should be the ESS.
AFAIK a declicker for vinyl should be specifically designed for the task for best results. You want something that first applies an inverse RIAA filter (IIR, and with enough headroom of course) to restore the clicks to a sharp impulse, then declicks, then applies RIAA again, and ideally you want 96 kHz recordings to make the clicks even easier to spot.
Plan B would be using a flat preamp of relatively moderate gain (maybe 20 dB, or in this case even a unity gain buffer) that only needs to accommodate the cartridge's loading needs and source impedance (this would probably have to be a DIY or mod job), then applying digital RIAA after declicking.
Make sure you don't push the peaks into clipping. In most cases -16dB LUFS should be OK but some quiet songs have high peaks and they'll need to be boosted. You don't know the peak to LUFS ratio unless you measure both.
There are quiet-sounding songs with high peaks By default, ReplayGain (and related) check for that if the file needs boosting, by default, they won't push the levels into clipping (so you can end-up lower than the target loudness). The streaming services also do this and I assume Sound Check does it too.
With compilation albums I usually research and update for the original release year for each song.
My setup is:
  • NAD PP2e pre
  • Evo 4
My process is:
  • rip 24/48
  • de-crackle
I'd think you'd want the AT-VMN95SP stylus, as it's designed for 78s.
My setup is:
  • NAD PP2e pre
  • Evo 4
My process is:
  • rip 24/48
  • de-crackle
I have been following this thread because I am in the process of gaining the needs necessary to move my vinyl library to digital so I can put the albums on my new DAP.
My setup is:
Technics sl1300 + AT VM95ML
Toppings DX5II DAC
NAD 114 Preamp upgrading to APT Holman Preamp 110 , presently recapping
My questions:
Do I run the TT thru NAD or DXii
Do I run the preamp/DAC preamp into USB interface, then
USB interface to PC
What cabling would be required for either scenario?
I think I have the software with VinylStudio and ill look at the options for crackling, etc
Any help is greatly appreciated.
My setup is:
Toppings DX5II DAC
My questions:
USB interface to PC
I also do not have a USB interface, recommendations? Most I looked at are for guitar and voice. Are there any specific to AD? Something effective and simple
What kind of onboard audio does your PC have to offer? That may very well turn out to be good enough (assuming there's a line-in which should generally be the case). It's not like you need a studio-grade ADC to adequately record vinyl, and onboard chips and their implementations have become pretty good. If the digital filter seems questionable, just record at the highest sample rate supported and resample later to anywhere from 96 to 44.1 kHz if need be. (I think you want at least 96k for better click/pop identification anyway.)
Also note that Realtek drivers seem to default to a +6 dB input gain, so a bit more headroom could be unlocked if you find you're running into clipping on peaks. (This may be because the microphone input on some chips like the ALC897 clips soon after reaching -6 dBFS, though this should be of no concern with the line-in.)
Access old input device properties from the system sound settings in Windows, where you can toggle level slider number fields between % and dB display. (Avoid input gains of <0 dB.)
The recording setup I'd use is
Technics --> short RCA cable --> NAD phono MM in, tape out --> RCA to 3.5 mm cable --> onboard line-in.
Best positioning of turntable and preamp is arguably back-to-back, but if you can stack then without any extra hum, that's fine too.
The DAC would only see use for monitoring and playback.
Monitor on headphones and avoid bumps and vibration. Something like a concrete slab on halved tennis balls underneath may provide the necessary isolation if need be. (The first-gen SL-1300 is not a subchassis player yet, apparently.)
Clean records extremely well, consider wet playing. Check strobo for speed accuracy at each side. The user-accessible pitch pots and their trimpot counterparts (plus speed selector) should have been previously cleaned so that they operate smoothly and without dropouts. Unstable speed only on 45 may be an indication of some recapping action being needed. (TL;DR: Turntable and records should be in tip-top shape.)
Also, always check whether the record in question can be bought in digital form with sensible mastering levels and such. Ripping vinyl is a slow and tedious task at the best of times.
My setup is:
Toppings DX5II DAC
My questions:
USB interface to PC
You need something to convert the signal from the NAD to digital so you can record it on your pc.
You can either use a phono stage that converts the signal to digital and into your pc like this
Or you need an audio to digital converter from the NAD to your PC
(Or like Steph says does your pc have a line in ?)
