damascato79
- Joined
- Feb 7, 2021
- Messages
- 8
- Likes
- 0
Quick questions: how do I sent 2x of these amps so I can control the volume through an external preamp? Cheers!
I cant see how it stacksJust went live on Amazon, but the 20% early bird coupon doesn't work yet
Edit: 20% Coupon working on ebay, stacks with the 10% offered on the page
Late night math mistake for me, sorry! Looks like it gave 10% + 10%, for $28.50 off, just short of the full 20% ($30 off), same as you. Fosi sent me a new Amazon code this morning, which gives the full $30 off, but it doesn't stack on Amazon either.Its not working for me. It does the 10% off $149.99 = $134.99 and the discount code takes off $13.50 for a total of $121.49.
What final price did you see?
Seen @ Fosi Audio site:
* V3 specs: Power 300Wx2 @4Ω, SINAD 88dB, THD 0.003%, SNR ≥110dB
* ZA3 specs: Power 155Wx2 @4Ω, SINAD 89dB, THD 0.006%, SNR ≥106dB
Something feels wrong at those specs:
* Regarding Power: one or both of the stated values seem wrong
* Regarding SINAD vs THD: SINAD increases AND THD increases too? If I am not wrong, when THD increases SINAD decreases (and vice versa), as they are representations of the same physical and measurable property.
Based on the values published at the Fosi site, Fosi ZA3 amplifier will be a worse amplifier than the Fosi V3. All this happens as some TPA3255 boards start to measure really well here at ASR (for instance: 3e audio TPA3255 260-2-29A).
A sugestion at @ Fosi Audio:
a) take a serious look at 3e audio TPA3255 260-2-29A, that seems to be the golden standard right now; can you sell us a box that does just that?
b) sell us a FOSI V4 with proper PFFB TPA3255 board + a good internal 39V/10A power supply + a metal case / dissipator (like you have done with the ZA3). Forget about sub-out and multiple front switches. Leave a back switch to switch between 2ch and 1ch output (this is the other reason to have a proper builtin 10A power supply).
I will be among the first to buy such an amplifier (just for the fun of it)
Read again my post as it has nothing to do with the current vs voltage debate.The "current limited" vs "voltage limited" debate has already been discussed for TPA325X amps.
The choice of PSU will depend on several factors, including the speaker impedance and also the choice of module (PBTL Mono / BTL Stereo)
The specs found in Fosi site and in the V3 and ZA3 user manuals, refer to both amplifiers using the same 48V5A PSU.
When in doubt just read the manual...
Do you realise that even your DIY pffb amp was more than twice the price of this amp?
I never understood whether there was significant benefit of PFFB.
That doesn’t really help thoughwhether its important or not is up to you
however its clear Fosi care and I'm guessing the rest will follow
they already said there next unit will feature this and didnt they buy an example amp from that Phillipino outfit?
The Chinese copying <Ahem> researching the competition.... so what else is new.
As I understand it, a careful implementation of PFFB can result in an amplifier with lower measured SINAD than the same without PFFB.That doesn’t really help though
Can you articulate what the benefits of PFFB are?
@Fosi Audio Audio thanks for your exciting update regarding PFFB.Thank you for your advice. Our R&D team have been focused on implementing PFFB for the past few months and has recently made significant breakthroughs. Stay tuned, as we might introduce a new amplifier supporting PFFB as early as next quarter.
