I have been following your posts for some time and generally agree with and appreciate your comments: "À tout seigneur tout honneur".
However, it is worth noting that the name of the forum is "Audio Science Review"', not "Audio Faith Review".
So let's look at the science, i.e. the published and verifiable specifications provided by TI.
From TI spec. sheets:
TPA3251 = 175W , PSU 36V max.,
TPA3255 = 315W , PSU 53.5V max
but, upon closer inspection of the specification sheets, we can see the more realistic values:
TPA3251 = 50W under a 8R load
TPA3255 = 100W under a 8R load
Facts:
- There is a 3dB (i.e., double the power) difference between TPA3251 and TPA3255 chips.
- Sylph uses the chip at 38V, which is above the maximum voltage recommended by the chip manufacturer.
- Reliability suffers and bad things happen when electronic components are persistently used above the manufacturer's maximum recommended voltage.
Well, ok, This is starting to resemble the
"much better" unit of measure that has been discussed on this forum before.
However, if this were an "Audio Faith Review" forum, faith rather than science would be the appropriate basis for discussion.
In that case, it would be best to defer to an expert: "For those who have faith, no explanation is necessary. For those who don't, no explanation is possible" -St Thomas Aquinas.
If this were an "Audio Faith Review" forum, I would even go so far as to say that the
Fosi V3 PFFB Stereo will, in due course, be a better value proposition than the Sylph FB100 or the 3E Audio. --Subjectivism dixit
Warmest regards.
