Fosi Audio V3 Amplifier Review
Rate this amplifier:
    Votes: 11 2.0%
    Votes: 44 7.9%
    Votes: 260 46.6%
    Votes: 243 43.5%
I have both the v3 and the bt20a pro and I think they are identical, except the bt20a pro has bass/treble tone controls and Bluetooth. I don't know if measurement would show a difference, but my ears can't hear any difference. I also can't think of any technical reason why there should be any difference but someone may correct me.
The only difference might be that you can do very limited room/speaker correction with the tone controls, but there are better ways to do that if it's important.
Ears though being a good measuring instruments are also prone to bias and other errors. I think a technical measurement would be very interesting.
that said, if i may ask , why do you think they are the same? Did you open them up and compared ?
Cheers
Hi All bought three of these to run the 6 surround channels on my anthem mrx 1120. From what I understand those 6 channels on the anthem are class D at 60 wpc where the 1st 5 are 150 wpc class ab I think. Was thinking perhaps offloading those surround channels might help out the lcr and two main surrounds on the main anthem amplifier that tested ok here, but I didn't see measurements with all 11 channels driven.
Anyways when calibrating I have to run each of the V3s at greater than 75% volume to hit the target spl level to match the other speakers on calibration. I do have room to go up on the output gain (I'm at 5 now it goes to 12). I was surprised by this as the anthem class d amps at 60 watts only needed a gain of plus one to get to the 70 the others are calibrated at. I thought the v3 with the 48 volt power supply would be better than the anthem.
BTW I think it sounds great, ran a quick test of some scenes from mad max and bladerunner and I thought it sounded better. However I thought it sounded pretty great to start with so who knows.
Anyways Long question short is there an optimal spot for the volume knob on the V3. Pic of the speaker specs in the next post.
The 4 atmos speakers are the paradigm e80-a and two surround back are e80-iw if that helps.
Yes the optimal spot is the lesser of max, and the point where it would damage your speakers. If you're controlling from an AVR with its own level balancing / room correction then you should definitely max it and calibrate it via the AVR.
It's not about power, it's about gain.
Plus - in any case - your speakers are 8ohm, so even at full power the Fosi is only able to drive them to 90W - which is only +1.75dB compared with the AVR 60W
"Anyways when calibrating I have to run each of the V3s at greater than 75% volume to hit the target spl level „
75% does not necessarily mean something. You can`t "directly compare Device A is louder than Device B when the Knob is at 12 o clock“ in a way.
they would have to have the same Input sensitivity and you would have to feed them the same Signal Volume.
Maybe the V3 Input is less sensitive ?
What do you think about the Edifier p17 and p12 speakers.
both have almost the same specifications
nominal input 5/20 watt
impedance 6 ohms
frequency response 55hz-200khz
4 inch
Thought maybee offloading the power supply of the main amps might help it. Haven't really bought into the whole separates thing in home theater yet. I wanted to give it a try without having to spend a ton on the amps. Probably would notice more of an impact with seperates for the LCR channels, maybee monoblocks. But Can't find something that would best the 1120 main amplifier section in this price range. Been kicking around getting the 3 channel buckeye purifi or hypex but that bumps it up to like 1500. Not sure I'm willing to shell out that kind of cash to run the experiment. Any recs for the mains?
Yes, it will - more power will be available for LCR when driving all channels.
My point was to answer your surprise that the external amps needed to be turned up to full - this is to be expected.
Your external amps are connected after the preamp. The internal amps - after the preamp - are also turned up to full. And depending on the gain - might even then still have a higher gain than your external amps - even though they can deliver lower max power.
Looks like there is a new V3 (Mono) coming soon with PFFB support !!
And a SINAD score > 100
Mono block support first - then a new V3 stereo model
Ooooo..this is cool! Nice..nice..!!
Cool ? Most of the users need a Stereo module... That s not cool at all to pay for 2 mono amps and therefore double the price...
Like you I'll wait for the stereo version and maybe wait longer until it also has a usable high pass filter but mono is useful for people who want to use a separate amp for L and R, doubling the power as well as the price
With
This a PBTL amp you wont double at all the power but only get about 15 % more power... Check 3E Audio mono vs stereo measurements ))))
Thank you @daniboun !!! Finally a proper observation of the fossiaudio story. Everyone hysterically praised the V3, and then we found out that the elemental thing that is recommended in the manufacturer's documentation, which is PFFB, was not incorporated. Of course, it will be solved in the V6 version! Cheap manager games.
I ask two elementary technical questions on the Fosija Community site, but there are no answers. Just enough to show how much they respect customers. Ask this question about total power in mono version then wait for answer???
I had the problem that the two screws on the bottom side were glued, and then a drill and a lot of trouble for the experienced.
I could add more, but I don't have time for that. Who is to blame for reading a lot of rewiew? All praise, but on a theoretical level.
The lack of PFFB is precisely one of the very first criticisms that were made IN THIS THREAD to this product and precisely by this community, so I read your comment and I just can't understand what the hell you are talking about, in any case for the 90 euros requested, it remains a small amplifier with an exceptional value and all this enthusiasm in despising Fosi seems truly out of place considering how open they are to comparison and improvement.
For me it's cool..will buy it. If you don't like it, skip it for another model amplifier. Why bother my decision? If not cool for you, so be it. Chill...
I purchased this little thing today from our local builder store, this one cool too:
max 54VDC 5-20A + extra 12VDC CT (PSU).
Opamp dual NE5532 original MSOP HG, big inductor with high Q.
All input balanced.
Protection UVP, OVP, OTP, OSP, DCP, resetable protection. (With socket to add as push button reset)
Mode with jumper pin:
BTL 2 channel speaker 2-8ohm
4 channel speaker 4-8ohm
2.1 channel
$34 with no casing.
