GaryY
- Joined
- Nov 25, 2023
- Messages
- 381
- Likes
- 386
Thanks again and it sounds it makes sense. I'm already much happier than before, but just curious and want to know why people would like to makes sound perfect. The obstacle is honestly I don't have the experience of "WOW!". or not sure if I know it or not. I don't have to hurry, but I would like to dig into it from time to time.For beginners, I recommend you do both. You will be taught how to use your program, and you will get a set of filters to use. After that you apply what you have learnt and try some variations. Maybe different XO points, maybe different target curve. You should repeat the entire correction exercise at least once to make sure you understood what has been taught. If you fail or get bored ... at least you have a set of filters that you can use.
BTW, I should remind you that DSP is specific to your setup, down to the last minor detail. If you move your listening position, you have to redo the DSP. Or like me, all I did was rotate my system 90 degrees in my listening room, and I redid the DSP from ground up. Needless to say, if you move home, you have to redo your DSP.
Thanks again.
