kdipner
Have bought the same, formatted to exFAT, works well so far, no issues.I just got a 2tb Samsung 980 pro NVMe ssd.
Should I format NTFS or exFAT?
Does someone have an opinion on folder names?
I can't recall which format I went with. The Eversolo creates a default folder called "EversoloMusic" or similar on the drive where your library will be stored.I just got a 2tb Samsung 980 pro NVMe ssd.
I would hope so. That's what I plan to do by way of the XLR analog outs. It has a dedicated pre-amp ckt. and a volume knob, so yes you can. Just use one of the analog outs and make sure the volume setting is "variable." I think it has RCA as well.
@jiji, you confirm my feelings with this streamer, the DMP preamp is of a good level, in this mode, the sound is very pleasant with great clarity as you say, the bass is present, but well proportioned in my opinion because the registers (bass, midrange and treble) are balanced. Z8 DAC owners have reported being confused by the bass reproduction, I think people preferring less noticeable fast bass. As you say, it's an excellent package (Streamer, DAC and preamp) at an extraordinary price. As I listen, I find its DAC to be of a very good standard (higher than I thought), the reproduction is faithful and detailed while remaining musical. The fact that you do not report a glaring difference in favor of the Topping D90, a quasi equivalence, which is considered a very good DAC is interesting for owners of DMP A6. Thanks for getting back with your power amp in your setup.Finally got the eversolo DMP A6. + remote
Ordered with Hifi79studio netherlands and got in in 2 days with 2 years warranty. That was quick.
Package was really good so as the device.
Connected as internal DAC+ Preamp as XLR to my NAD C298 and played some FLAC files (ripped from my CD) .
First impression is i'm impressed by its clear sound. The diffeence i hear is the bass is bit tighter in Topping D90 compared to A6 Dac which is a bit exaggerated. Otherwise it sounds great. Anyway i like this bass but may be some one don't.
Preamp is really good compared to topping D90 internal preamp(passive) and this is what i'm looking for a long time.
Overall package is tough to beat (Streamer+clean DAC+Active preamp).
I'm happy with the purchase and the sound.
I will do more checks by sending the RCA out to my marantz cinema50 to hear how that sounds(through Dirac live)
There's also analog input but i think everything will still need to be processed by the Internal DAC before output but if say the DMP-6A DAC converted outputs are already more superior will a inferior DAC from AudioEngine A2+ still process it? Just trying to get the understanding of things. If my understand is wrong please go easy on me hehe.@DarkSensation: Your A2+ speakers only accept USB or aptX Bluetooth input. That means you can't bypass the A2+'s internal DAC - it's the final leg of the chain before amplification to the speakers.
I'm guessing the A2+'s DAC is not up to the same standards as the Eversolo, but I haven't seen SINAD measurements of the A2+'s DAC. In any case, you're not getting the full benefits of the Eversolo's DAC if you run it this way.
I use a pair of Genelec 8020 with mine - works nicely.Any idea what desktop sized speaker is good for DMP-6A
Now, when I play with an external dac via usb connection there is no ticking sound through the speakers when I change source. Could be the update or it was just the click from a relais or something.Is it possible that you are simply hearing the audible tick from inside the A6 when inputs are changed ? It's a fairly noticeable tick, sounds like a relay, it doesn't come through my speakers.
You say you hear a difference in the bass but as Keith @Purité Audio has already noted, both the DMP-A6 and the D90 have a flat frequency response. You have Dirac Live so I presume you have a measurement microphone, therefore you can test this. Run a sweep at your listening position with REW using the D90 and then do the same using the DMP-A6, and compare the results. This will confirm if you there is any difference in bass between the units. I suspect the results will be the same with each unit, providing you volume match and change nothing between tests other than replacing the DAC. It would be great if you can share the results, thanks.Finally got the eversolo DMP A6. + remote
Just a quick question, does de A6 do the formatting? Or do you have to buy a separate device to do that. Waiting on the Eversolo DMP-A6 Master Edition, somewhere this week I hope...Have bought the same, formatted to exFAT, works well so far, no issues.
Ive seen many people bought the Samsung 980 pro NVMe SSD 2T. Did someone here buy this Samsung version with the optional heatsink? With so many words: will the Samsung 980 pro NVMe Ssd 2T with heatsink fits the A6 without any problems?Have bought the same, formatted to exFAT, works well so far, no issues.
Very good question . I used same XLR cables and same amp(Nad C298) for both D90 and A6. Only difference is D90 i didnt used pre amp mode as i can control the volume control using my RAspberry pi4 Volumio app and in A6 i have to use the pre amp as C298 have fixed volume. Difference i have is the preamp and dont know if that can contribute to this bass difference?But they both have flat frequency responses so where does the ‘extra’ bass come from?
Sorry i sold my Topping D90 last week. So cannot make comparision sweeps now .You say you hear a difference in the bass but as Keith @Purité Audio has already noted, both the DMP-A6 and the D90 have a flat frequency response. You have Dirac Live so I presume you have a measurement microphone, therefore you can test this. Run a sweep at your listening position with REW using the D90 and then do the same using the DMP-A6, and compare the results. This will confirm if you there is any difference in bass between the units. I suspect the results will be the same with each unit, providing you volume match and change nothing between tests other than replacing the DAC. It would be great if you can share the results, thanks.
Yes, A6 will offer you to format the drive as soon as you select it from the „Files“ menu, you simply need to choose between exFAT and NTFS.Just a quick question, does de A6 do the formatting? Or do you have to buy a separate device to do that. Waiting on the Eversolo DMP-A6 Master Edition, somewhere this week I hope...
For myself I decided to go without heatsink as I am not expecting the drive to be in use very often as I mostly directly stream from Roon. My understanding is the SSD reading only operations are also significantly less energy intensive compared to writing, therefore in my personal opinion the amount of heat generated by an SSD shouldn‘t be an issue. But I might be wrong, if there are any experts among us, please correct me.Ive seen many people bought the Samsung 980 pro NVMe SSD 2T. Did someone here buy this Samsung version with the optional heatsink? With so many words: will the Samsung 980 pro NVMe Ssd 2T with heatsink fits the A6 without any problems?
