I have had powerful EQ in my receivers (Dirac, Audyssey xt32, YPAO 64 bits) that I have finetuned with REW and an Umik-1 micro, getting a flat response in my room and then applying curves to my liking (eg Harman). But somehow EQ did not feel natural
Yes.Hello. A question because I was about to get one but, reading the manual, it states "Note: * all digital input connections only support output audio by analogue output, not digital output".
Thus, is it possible to play DSD multichannel files located in a PC/NAS connected by USB or Upnp (Ethernet) to an AVR using HDMI output?.
I'ts the most important spec for me.
Thanks!
It's good to see you getting slowly deprogrammed.somehow EQ did not feel natural
I have found that in terms of EQ really is ‘less is more’ I would only correct the low bass ( in the minimal phase region ) and leave the rest of the FR to look after itself, I found even with Dirac only adjusting the bass was best.I have had powerful EQ in my receivers (Dirac, Audyssey xt32, YPAO 64 bits) that I have finetuned with REW and an Umik-1 micro, getting a flat response in my room and then applying curves to my liking (eg Harman). But somehow EQ did not feel natural
Thanks. I appreciate your patronizing condescendency ;-)It's good to see you getting slowly deprogrammed.
Yes. I only correct schroeder FR, which in my room is around 410hzI have found that in terms of EQ really is ‘less is more’ I would only correct the low bass ( in the minimal phase region ) and leave the rest of the FR to look after itself, I found even with Dirac only adjusting the bas was best.
That's "condescension"!Thanks. I appreciate your patronizing condescendency ;-)
Thanks againThat's "condescension"!
Couldn't help myself.
Thank you very much! Now I use this mess: PC->Ethernet->Pioneer UDP-LX500->HDMI-> AVC X3700H... so, this would be VERY helpfulfor MCH and, for stereo, I could just plug it into the Yamaha A-S2200 trough XLR....I think I'll pull the triggerYes.
