ctrl
Does anything change when the gate is placed at this position?
This seems to me the best compromise. I wonder, is it possible to lift the speaker in the air a bit so that you could negate the doubling of the baffle more?Test # 4) Ground Plane Measurement: Speaker Angled ~ 8 degrees; window out to 40ms before first reflection.
Speaker was angled at about 8 degrees so that the tweeter would be pointing on-axis with the microphone (well, as on-axis as it can be without burying the mic and pointing the mic at the DUT). Note that while the response was gated here, if I were to actually use this method I would move to the back yard where I could get the nearest reflection about 40 feet away which should get me down to around 20hz. So, this was more a sanity check test.
Pro: Invulnerability to reflection; I can get ever further out in my backyard. High resolution in to the very low frequency region.
Con: Outdoors. Diffraction effect of speaker changes due to the baffle doubling (via the mirror image effect). HF > 10khz seems to be a pain. From my research that's generally accepted as questionable. Though, I had decent results.
Phone placed at tweeter on baffle and used in 'selfie' mode to make sure the microphone was at the center of the image (trick I learned on another website).
Here's the result compared to Amir's:
And would it be possibel to do measurements to a 90- degree angle in this setup? Or would the angle of the speaker be tilted differently on every measurement?
This looks better than the first measurement. Significantly fewer ripples in the measurement.At this point, I think I'm willing to simply chalk this up to measurement method and call it a day... But I will attempt a closer measurement to see if this changes the trends I am getting in the response.
See below. This is all smoothed to 1/24 Octave.
It creates a lot of ripples (error). I wouldn't use this. *IF* I were to use the GP method I'd move it to the backyard which is a bit further away from any surface. Or just chop it at the first reflection and let it ride.
...The ~1dB pk-pk "noise" looks like a modulation at ~25Hz, some sort of analysis artifact (artificial) from the 0.1s impulse windowing...
I could be wrong but think the riple is from natural boundarys, one can model boundary's in free spreadsheets from Jeff Bagby, to see only one boundary at a time cheat the spreadsheet set other boundary's to infinite as in below curves, the green 40feet curve is what Erin say he can reach in his backyard and the brown 14feet looks a bit like the ripple you talk about and could be the fence we see in the outdoor picture for Erin's 5 feet stand, blue 0,54feet curve is Elac DBR62 woofers center distance to ground plane.
Are you using rectangular windows? If so, make sure window marker and cursor are set on zero crossings of the impulse response. If not, time aliasing occurs and false ripple creeps into the measurement. As a guess, this might explain your ripples.
