Our member @ctrl has a series of treads where he measures differences or rather not in for example crossover applications with capacitors .
Besides sighted ( invalid ) testing , some cheaper ones have great spread in tolerances and then you change the circuit and ofcourse it’s different duh and hobbyists replacing caps in random speakers does not account for series resistance and then also change the circuit, duh again these factors may be bigger than the actual differences if they exists.....
And if your read kef’s white papers of later years they do distortion measurements of crossover components and explore them deeper , but there still no voodoo or very expensive components used just ones fit for the application .
I’m more interested in the actual end result the performance of these speakers , can someone send Amir a pair
Search results for query: Capacitors
www.audiosciencereview.com
