- Joined
- Oct 25, 2019
- Messages
- 12,491
- Likes
- 18,102
WASAPI (Windows Audio Session API )
Summary Recommendations:
- Install Equalizer APO and use it to disable original APOs and set EAPO's preamp gain at ~ -4 dB to avoid upsample overs, filtering induced peaks, and the Windows CAudioLimiter
- Set Windows audio to 24 bits so that it's added dither doesn't compromise dynamic range
- Set Windows sample rate to the same rate as the native file, or to 96 kHz if you play back high resolution material
- Turn off Windows system sounds and enhancements
- Install "remote desktop" for "Spotify Connect"-like added convenience, for all your digital sources
- Take the money saved and buy more music, better speakers and a few bottles of wine
Are you using Win10? If not what are you using?Anyone care to say more about how to implement this I'll get my new PC in a month
- Set Windows audio to 24 bits so that it's added dither doesn't compromise dynamic range ?? how
- Set Windows sample rate to the same rate as the native file, or to 96 kHz if you play back high resolution material ?? how
- Turn off Windows system sounds and enhancements ?? how
- What software player is recommended thats plays nice with EqAPO and can it be used with ASIO or WASAPI or could is it just not needed . Could the uppsampling to 24/96 for music use be done in the playback software at the same time as windows is set to 24/96 even if windows got good enogh , i suspect some third party applications are even better
As per this.>
I don't know the solution for this. Perhaps another peep can help you.
foobar2000 does it automatically out of the box, with the bundled SSRC resampler. If the source sample rate is different from the driver's sample rate, it will be automatically resampled to the driver's sample rate. That means, there is no need to add another resampler in foobar2000's DSP manager. If you have another resampler plugin installed, you can configure it here:Could the uppsampling to 24/96 for music use be done in the playback software at the same time as windows is set to 24/96 even if windows got good enogh , i suspect some third party applications are even better
Nice , I assuemthat windoes is smart enough to not apply any uppsampling if it recieves the correct rate from the playback software .foobar2000 does it automatically out of the box, with the bundled SSRC resampler. If the source sample rate is different from the driver's sample rate, it will be automatically resampled to the driver's sample rate. That means, there is no need to add another resampler in foobar2000's DSP manager. If you have another resampler plugin installed, you can configure it here:
I've tested these resamplers. Search for "It has two bundled resamplers" in this article for the tests.
http://archimago.blogspot.com/2019/06/guest-post-why-we-should-use-software.html
When you do that Equalizer Apo isnt working anymore btw.To disable/enable audio enhancements. This will be very close or the same as my PC. Make sure you select the correct audio device you are changing the setting for. Do this>
Thanks for the heads up on that. I don't use any of this stuff you guys are using and I simply answered @Mnyb questions.When you do that Equalizer Apo isnt working anymore btw.
I don't use Spotify but you can have a look at this plugin:Nice , I assuemthat windoes is smart enough to not apply any uppsampling if it recieves the correct rate from the playback software .
For spotify I'm content to have windows doing it.
Did you try MPC-HC? I don't use EQ APO, but the player's built-in volume control does not clip in my setup.Btw regarding the testclips a.mp3 and b.mp3.
foobar is not just the only player removing the distortion from file a.mp3, its also the only volume control (inside the player) which restores dynamic range.
You can check it with peace in the vu meter. If you lower windows or EAPO(preamp) volume dynamic range is 0 since the vu meter is always full.
When you lower volume inside foobar dynamic range comes back (vu meter jumps up and down).
From this info i would say EAPO preamp shouldnt work like its advertised in OPs first post.
I did not yet. I tried mpv, Spotify and IrfanView, since i have no other apps which read mp3.Did you try MPC-HC? I don't use EQ APO, but the player's built-in volume control does not clip in my setup.
https://www.audiosciencereview.com/...indows-audio-quality-debate.19438/post-643579
Could you list the other players you tried that failed the test as well?
