Are you looking for subs mainly for music, mainly for movies, or a combination?
Here is another option.
Though i find it hard to figure the spl specs on the kh 420s. Will the subs be totally overkill?
KH 420 + DIM 1
KH 420 + DIM 1 - - Midfield Monitor,Up to 11 m (33 ft),Down to 26 Hz,Down to 34 Hz,Down to 52 Hz,Down to 57 Hz,Digital + Analog Input,Professional Recording Studio,Delay,Up to 6 m (18 ft),Up to 4 m (12 ft),Up to 3 m (9 ft) - Sennheiser Discover True Sounden-de.neumann.com
2x
XTZ Cinema SUB 3 X 12 Subwoofer - Sort THX, 2700 watt - Audio Import AS
XTZ Cinema SUB 3 X 12 Subwoofer - that’s true cinema! XTZ Cinema SUB 3 X 12 Subwoofer - that’s true cinema! har flere ganger vist at de kan subwoofere,...www.surround.no
Only music.Are you looking for subs mainly for music, mainly for movies, or a combination?
Maybe i should specify why i think its a good idea to go for satelites/monitors + 2-4 subs.
1) pro audio i believe is truer to sq vs price then fancy consumer electronics
2) most midfield monitors for less then 50k dollars require a sub
3) the waf factor. Setting up the subs in corners/by a wall is waf. Pulling out the monitors to perfect position is easier with a small box. Planning on running 2 dsp/eq modes - waf mode all speakers away at the back wall. And then critical listening mode. Hopefully leaving the heavy subs by the wall bounderies…
Alright. So the finalists are as following:
1) Genelec 1038s
2) Neuman KH420s with 2-4 subs
3) Dynaudio Core 58s with 2-4 subs
Guess i will have to find a place to test them. Would be fun to do a couple of daytrips to Denmark, Finland and a weekend trip to Berlin. Living in southern Norway all is doable by car.
Any thoughts on the contenders?
I read from the Neuman speaker manual that if you use multiple subs they should me no more then 2m apart. Can anyone explain that Logic to me? Should this then be applicable to full range speakers as well? Makes it kinda hard for mid/farfield listening at around 3-4meters.. they also recommend placing the main monitors no further then 0,8m from the back and side walls.
Guess a «acousics for dummies» would be a good investment..
That's yes, yes, and hell no.Alright. So the finalists are as following:
1) Genelec 1038s
Ok, hell no to Dynaudio??? any reason?That's yes, yes, and hell no.
Minidsp is going to do the job cheaper with multiple subs.
1) Genelec 1038s
Thanks for the great advice. Where can I find these guys? must say its rare these days not to find any info about them on the internet. Do they have a web page? I find the Ino-Lab Audio educational page, though nothing about their speakers exept from used listings and interviews with people owning them...Ino Audio in Stockholm
Dynaudio doesn't measure great, and it's poor for the money. Check the spinoramas.Ok, hell no to Dynaudio??? any reason?
Planning Minidsp studio just to get a reliable streaming box which i might use to do anoterh test/dsp after the built in dsp's has done their jobs. Not quite shure i understood what you said about minidsp as Neumann and Genelecs built in dsp's can handle multiple subs...
And no, I have not excluded the Genelecs - 8351 or 8361's both with subs.
Another resent competitor offfering a nice package is the Adam SV3 with two of Adam Audios own 2 sub15's.
And to the q's about using other sub brands then the speakers - the only reason why i want to stick with one brand is to make the setup easier (room correction). This might be a stupid thought though as the minidsp studio might do the same trick - AND I could save a lot of money on getting used subs from known non-pro-audio brands. Eg. B&W, REL, JL+++
You have to give Ingvar Öhman a call. Mind that, there is usually a quite long waiting time for his speakers. But if you are in search for speakers in that price range with subs and if you are planning to travel around a bit for sessions, I might be a good idea to pay a visit.Thanks for the great advice. Where can I find these guys? must say its rare these days not to find any info about them on the internet. Do they have a web page? I find the Ino-Lab Audio educational page, though nothing about their speakers exept from used listings and interviews with people owning them...
+ 1000While I have never owned a Ferrari, I don't find the fact that I've owned BMWs to be deflating. There's always a bigger fish, and down that pathway lies madness. People spent hundreds of thousands and more on stereos that are problematic at best and no match for a pair of 708P and a sub or two.
