Dutch & Dutch 8c Review
fluid
The W371 is way out of my price range regardless! :(
Considering my problematic area is basically everything below 200Hz, I suppose the ideal setup for me would be the D&D 8c with properly set up multi-subs to get smoothness across that whole range? I can't help feeling I'd miss out on the benefits of the coaxial Ones as my position on the sofa is quite variable.
Right now, I'm crossing over a single sub at 120Hz to improve my sub-bass response (speakers can do down to 40Hz normally) but this creates a wide dip between 100-200Hz . I've identified one more possible location to test the second sub although it suffers from low WAF!
Multisubs don't help smoothness across the frequency range per se, they allow for reduced spatial variability, a smoother response over a larger area. Without EQ correct positioning or other adjustments more sources can make the situation worse not better.
Instead of buying new speakers why not start a thread, post some information and measurements and get some help to make what you already have better?
ferrellms
Regarding distortion, I've done experiments on that exact thing with Kii Three and my poor man's version of BXT after I was mind-blown by BXT in demo.
It matters. It matters alot. No question about it, small speakers with limited capacity cannot compete with more capable stuff when it comes to bass quality.
Crossing my poor man's BXTs over at 200-250 hz compared to Kii alone simply changed the visceral impact of the sound, even at moderate (75-80 dB) levels.
One thing to consider when choosing to go full-range with a small stand-mount speaker like Kii or Dutch is that you'll have SBIR effects from the floor/ceiling that the cardioide won't help you with. Usually a wide-ish dip in the midbass around 100-150 hz depending on distance from the driver to the floor/ceiling.
Compensation for that will eat capacity in an area where those speakers are already struggling with the distortion (due to phase cancellation from cardioide?) and might actually end up reaching the limits before the lower end does.
I've posted these measurements so many times before that I won't spam them in here as well, but we're talking near 20 dB reduction in distortion with subs at 75-80 dB after Audiolense compensating for dips in that 150-250 hz region.
Audibility then doesn't really become a question, it's a given. The question we should be asking is if the sacrifice in distortion is worth it to achieve better directivity?
Below 300 hz I'm not sure, really. Perhaps.
I don't see any floor dips in any of the in-room measurements I've seen of any of these speakers. And you can lay acoustic absorbers on the floor...
All of this theorizing about "which is better" based on technical details is mostly hot air about things that minor EQ adjustments could alter or fix. And issues with super loud listening distortion are not of interest to most people. A couple of experts with access to each of these speakers has noted that they could probably be EQed to sound practically the same.
Absolute
By Odin! I am tired of providing detailed measurements with different experiments to show that there's no magic involved. Here I will provide you with impulse response of a single Kii Three with and without floor absorption so that you can see the net reduction of the reflection strength at around 2 ms.
Where there's a reflection there will be interference. Make of it what you will.
Blue is no absorption on the floor, Red is with two 4 inch RPG Absorbors on the floor.
I can go further, here's a comparison of the impulse-response between Klipsch RP160M and Kii Three placed on the same stand in the same spot. Kii is taller, so floor reflection is a little later. Much difference between the strong floor reflection?
And here is what happened when I placed absorption on the floor with the Klipsch;
This only demonstrates that the BXT serves a purpose other than just more headroom. There's acoustic benefits of having several woofers placed at different heights. I wish somebody somewhere with access to BXT would share measurements such as these.
Kvalsvoll
Norway
I can show what happens with slightly better radiation pattern. The floor reflection often show up in the frequency response causing large deviations in the 300-1K range, especially in better rooms where all other reflections are attenuated, but this does not necessarily have that much impact on sound quality.
Here, in Room2, a small room with acoustic treatment:
Same speaker, a different room, ordinary living room, not treated, horrible acoustics:
The reflections at 1.5ms is partly from the seating, partly from a table in front of the listening position.
Same speaker, same horrible room, now at a different listening position closer to the speakers, with no table, note that the floor is hard wood, no absorption, no table or objects:
Scoox
Interesting that you preferred the 8351b. Also your room must be pretty big. I get ~30Hz extension with the 8351b here, and 8C went down to 20Hz iirc.
My 8351Bs go down to about 32 Hz as per the specs. With EQ I can coerce some extension out of it but a price is paid (harmonic distortion). I'm sure the same can be said for the 8Cs. Even if they go a bit lower, you'd still benefit from a separate subwoofer if I really need to go lower than 30 Hz, plus you get more freedom of monitor placement.
Digital_Thor
Denmark
I tried many times to play any solid bass under around 100hz with smaller drivers in larger rooms above 20sqm. And even though a smaller speaker can make quite a "boom", it never sounds like it really moves air.... because it can't... it's impossible with such a tiny membrane.
So my take it always to use subwoofers with speakers that have 8" woofers or less. They simply lack the physique of that "push" of air, that larger surface area performs. My guess is, that even though you pushed a 6" out of the speaker with explosive force. You would still just have the air escape around the speaker, and not push it forward - and absolutely never get that powerful compression of air in a room, that adds the sensation of big drums, explosions and any type of physique that bigger instruments and orchestras have.
I believe that there's a study - somewhere - that showed that we create sounds, octaves lower than what is played - if missing. So that if we hear 100Hz, we also think we hear 50Hz. So smaller speakers sound big - but they ain't.
Frgirard
the sub harmonic are a myth. we hear what is measured.
sigbergaudio
Norway
Well, sort of. What he probably is referring to is the opposite. Some smaller systems use clever compression to play the harmonics of a sound while they dampen the fundamental (because they're not capable of playing it). Doing this right makes it sound like the music is fuller than it really is.
Digital_Thor
Denmark
Drivers compress and decompress air, they don't move it.
Fair enough... but still, I'm yet to hear any smaller speaker - at any price or design - play deep or physical bass like a bigger speaker.
In theory - compressing air in a sealed room. Should be no different, with a big driver moving a bit, rather than a small driver moving a lot. That's simple physics - volume displacement. But few people live in a sealed room... and then surface area helps.
Emlin
Thor, have you tried it blind, because the waveforms are the same?
Digital_Thor
Denmark
Oh I wish I could. Only a few single blind, but not double blind. Maybe I'm being "cheated" by a simple volume issue. I know that things has to be level matched exactly for anything to be truly scientific.
I've just been to Norway and listened to two different systems. One with 32 x 18" subwoofers and one with 8 x 24" subwoofers. They had really nice, well treated rooms and excellent measuring systems. It simply sounded like super well-behaved - typical - HIFI systems, with neutral bass, great voices and clear highs - we did not play that loud actually - in contrast to what quite a few might think. Yeah yeah.... we tried the trick where everything moved... vision shockingly loud. But I had a finger in each ear during those 20 seconds :)
But the experience gave the clear impression, that normal "small" speakers, very quickly reach a level, where you see the driver move more and more, but the overall loudness does not keep up.
I did hear several Genelecs.... but without subwoofers, they still sound like small speakers. I'd love them to be able to go to 30Hz like a floor stander.... Cause they sound great. But..... physics.
Digital_Thor
Denmark
By the way. I'm sorry for getting carried away with my experience about subwoofers, rather than sticking more firmly to the Dutch and Dutch review. It was the Genelec part that got me going .
Frgirard
is it possible to have an exemple ?
thanks
sigbergaudio
Norway
thanks
Not sure exactly what you're asking me to give an example of, but you can read about the concept or what such a system takes advantage of here: https://en.m.wikipedia.org/wiki/Missing_fundamental
The effect can be heard in some piano recordings where they play the very lowest notes, but due to the difficulty of actually recording these low notes, the recording may not even contain the fundamental of the note. But we still "hear" it, because our brain makes up the fundamental based on the harmonic overtones. This can be taken advantage of with clever compression/limiter algorithms. It's also used as a production technique to get even richer bass sounds by playing with or adding harmonic content.
There was a thread about that phenomenon as well here on ASR a while back if I remember correctly.
dasdoing
Salvador-Bahia-Brasil
so far ok, but a speaker produzing harmonics to fake a missing fundamental is new to me.
btw the missing fundamental trick never worked for me. most pianos have very poor bass
