- Thread Starter
- #21
No idea sozDoes this do anything the Behringer DEQ2496 cannot?
But yeah, it shouldn't be very complicated or expensive to load small dsp units onto hifi gear these days.
That might depend upon whose patents you infringe...
Some 15 years ago, I got a TacT room correction DAC+pre-amp. It instantly sold me on its benefits. I took it to work, showed it to my signal processing guys and said we have to put this in Windows. Our member J_J led that development and it came to fruition in Windows Vista. As you, I consider the technology a must. It should become standard in every music player and pre-amp/DAC. It doesn't cost much these days to implement it.Why’s this not in everything?
Which speaker system did you set this up with?My speakers have ‘ come alive’ in a way I thought was not possible.
In my main system so my vivids.Which speaker system did you set this up with?
I’d add this worked as advertised straight out the box and the menu system is idiot proof..
Kal, Curious as to what you think about the Dspeaker's final results in comparison to what the Audyssey MultEQ XT32 in your Marantz 8802 is capable of?
Yes
It is hard to say a this point in time as I have not used the DSPeaker 2.0 for a while. Since I am almost totally MCH, the DSPeaker could not supplant the Audyssey in the Marantz. Now, I use the Dirac software and can avoid adding extra boxes and connections. The DSPeaker is on loan to a colleague who uses it exclusively for his sub.Kal, Curious as to what you think about the Dspeaker's final results in comparison to what the Audyssey MultEQ XT32 in your Marantz 8802 is capable of?
I know the Dspeaker offers quite a few more options, just wondering how far about they may be in not adding undesirable distortions or subtractions etc.
TIA
Had not thought about the option of just using it on subs. Good idea!The DSPeaker is on load to a colleague who uses it exclusively for his sub.
Amen.The behringer is a pain in the ass to use , it does not do a blend of FIR and IIR filtering..its really just a parametric eq. I used one for a while...
The Dspeaker is a great tool in that its dead simple to use and does what it says on the box ..automated and quick bass correction..
Thanks for the response, Did you find the Dirac software vastly superior to Audyssey X32?It is hard to say a this point in time as I have not used the DSPeaker 2.0 for a while. Since I am almost totally MCH, the DSPeaker could not supplant the Audyssey in the Marantz. Now, I use the Dirac software and can avoid adding extra boxes and connections. The DSPeaker is on load to a colleague who uses it exclusively for his sub.
I would not say vastly. I would say substantially.Thanks for the response, Did you find the Dirac software vastly superior to Audyssey X32?
