I can only agree with that---I made a very average score at klippel distortion test (that for music, but pretty good in two-/multitone test). However, if neither low distortion nor high SPL are not objectives anymore, I wonder what they might be.... Put another way, our ability to hear the test frequency noise tones at frequencies of 40 Hz and below is extremely crude. Indeed, the results show we are virtually deaf to these distortions at those frequencies. Even in the mid-bass at 280 Hz and lower, the noise can be around -14 dB (20% distortion), about half as loud as the music itself, before we hear it.
https://www.axiomaudio.com/blog/distortion
If you build one the frequency response will be all over the place and if you test this with sweeps it is clearly audible if you have nulls in your listening position in my case the frequencies around 40 hz are almost not existant.You need more than one subwoofer to even this out and dsp is not going to help because cancellation will be there despite the power you give. Also every subwoofer gives you another 3 to 6 db so you gain spl with the same thd.Also from the thiele small factors the SEAS does better in a vented box.For closed you need a driver with Qts higher than 0.45.In my opinion try with two Pioneer and if you dont like them sell them they cost 100 euro together.If you want tight bass you can make a bit smaller boxes and this will help with power capability.The um10 is probably more capable of punishment in high spl.If you can measure your room and find the nulls and run the sweep say from 20hz to 250hz you can here the problems clearly.I can only agree with that---I made a very average score at klippel distortion test (that for music, but pretty good in two-/multitone test). However, if neither low distortion nor high SPL are not objectives anymore, I wonder what they might be.
BTW, below are speakerboxlite.com simulation results for SB34SWPL (red curves), UM10-22 (green), L26ROY (blue) and RSS315HO (orange) in a 28L int vol sealed box. And they are almost the same in 40L or 50L box (well, except that in larger volumes cone displacement of L26ROY and RSS315HO exceeds Xmax, while SB34 and UM10 still have a 2-3mm margin).
And thank you for the simulation link, presenting several simulations on one plot is a nice feature. And I will probably go ahead with a smaller box--as all the wood is sent overseas, plywood prices are skyrocketing here;-)
The price of Scan-Speak revelators being way above my constraint, right now, the contenders are (in alphabetic order)
- SB Acoustics SB34SWPL76-4
- Scan-Speak 32W/4878T00
- SEAS XM001-04 L26ROY
Is the ScanSpeak Discovery evolution of Peerless XXLS (name escapes me at the moment) or Tymphany/Peerless's replacement (SDF or something like that - it has a larger diameter voicecoil and new basket, but only available in 10") available to you?
The subs must be placed in different spots than the speakers that cancellation is not going to dissapear. I feel you could benefit from a bandpass sub to fill that.Sure, that is exactly the idea---to build 2 subwoofers to complement the main speakers which already have "some bass'' (2x10" XXLS 835016 each). Just as an indication, here are current REW measurements at the listening position (1/12 octave smoothing): without EQ (green line) and with some minimal EQ (red one).
For a moment, I have not thought much about bass management implementation.
You are right, and I see now that there was a copy/paste error in my initial message---the scan-speak driver I consider is Discovery 30W/4558t00, not 4878 which is Revelator line. In fact, I have 2x10" XXLS 835016 in each Nao Note, and scan-speak's indeed look "familiar."
I have seen that mention of good ventilation of Scan-speak drivers. I am a bit confused with the derivative Peerless->Scan-speak->SB Acoustics, I assumed that SB34 inherited that feature, but according to the image below it has a pole vent.
I wonder how much space should be left for the pole vent? Finally, this may become a critical parameter.
Oh, hope this is not a joke! Where this information may be found?Maybe even more importantly, did you check that these drivers can be downward-firing?
