xarkkon
- Joined
- May 26, 2019
- Messages
- 228
- Likes
- 338
There is much discussion about the minimal space behind the driver magnet and the rear wall of the box. Opinions vary from 1,25-1,5cm to twice the diameter of the vent. From images of UM10-22 I have found, the latter would imply 6-7cm behind the magnet, with the box at least 22-23cm deep. This is clearly well beyond my geometry constraint. Life is not easy...
That being said, I wonder if such ventilation is needed for the driver which will hardly ever receive more than 10W of RMS...
my current plan for the UM10-22 is to have 1.5 inches between the rear wall and the driver, and to have the front baffle 2 inches off the ground. mind you, i don't really know the right answer to this and only selected those numbers because (1) front of the driver + xmax is around 1.6 inches so i added a bit of clearance off the ground on top of that at 2 inches, and (2) i needed to fit the downward firing sub within 10 inches for my space constraints (2 inches off ground, c. 5.75 inches for depth of woofer incl. front baffle, 1.5 inches of space, and 0.75 inches rear wall). hopefully someone more knowledgeable here would be able to comment if this even works to begin with
i do realise 10 inches is beyond your geometry constraint. what sort of height are you limited by?
