Petrushka
- Joined
- Jun 29, 2024
- Messages
- 1,695
- Likes
- 1,953
But I almost never listen close enough so that moving around doubles the distance.Smaller Genelec 83X1 series speakers are designed for near field monitoring, and so are many other smallish studio monitors. Basically, You need to first figure out the listening distance and SPL You want at that distance, and then select Your speakers accordingly.
Increasing speaker size does not change the fact that SPL decreases by 6 dB when Your distance from the speakers doubles. If You really want to have all the time the same SPL when You wander around the room, You need to build some kind of automatic tracking and volume control to compensate that.
On the other hand, there’s nothing unexpected about a sound source seeming louder as you get closer. But the tonality should, ideally, not change.
The first speakers I bought were Bose 901s, in 1968. I now have some Polk towers for my TV in the bedroom, and some KEF 105/3s in the living room. The living/dining/kitchen are semi-open plan, and quite large, with a high ceiling. The sound doesn’t change character as you move about, or at least the change seems natural.
Disclaimer: I’m old, so variations in the upper octave are outside my hearing. But I hear the lower octaves just fine, and the bass does not vary much.
