It might be true. Odors from electronics can sometimes be from electrolytics and corona. In this case a electrolytic may cause the odor.Good making up story
Do you work for devialet?
How can you be fairly certain? any evidence? Or you just make it up again like other stuff you made up?I'm fairly certain the majority of devialet owners are not audio forum members so your ' knowledge ' in this case is virtually meaningless yet you present with absolute certainty.
I'm not proposing f'all. I'm merely saying that a logical argument can be made.You propose full computer control...
I think it has to be either a fault in design or else a faulty unit. The Soundstage measurements of the Expert 130 do not show this issue.
https://www.soundstagenetwork.com/i...er&catid=97:amplifier-measurements&Itemid=154
Yes, and so do you .Do you work for ASR?
Let me re-post this from Devialet Expert 140 Pro page (so the same product tested by Stereophile's John Atkinson):
Expert Pro is the world’s most advanced audiophile system, meant for music lovers in search of a refined and emotional listening experience. Designed to replace traditional Hi-Fi systems, Expert Pro delivers all the core elements of playback – preamp, amp, DAC, streamer, phono stage – in a single and ultra-compact unit. By rethinking sound reproduction at every turn, Devialet engineers have been able to achieve the best performance ever measured, at all power levels.
What do you mean by this?One of the worse thing we can hear is someone blaming his competitors in the same industry.
No, I'm merely saying that the argument can be made. Devil's Advocate etc.Are you saying that all amps should be designed to have less power at HF as that would benefit SQ?
The mere fact that we CAN build an amplifier to provide the same energy at 20kHz as 10Hz is not necessarily an argument for doing so if, in the opinion of the designer, a better sounding result can be achieved by NOT doing so. I'd bet a crisp $10 bill that, if Devialet is eventually cornered into giving a response to all this, they run an argument along those lines.That is simply not true as today it's not a problem to design and build an amplifier that will have cosntant power at all freqs.
It's just more helical mind spin about nothing other than conspiracies and rubbish ideas.What do you mean by this?
Note that the Devialet distortion spec at 10W is THD, not THD+N. It seems that noise swamps the THD+N at lower power levels on these products.The problem here is the lack of full bandwidth power ratings.
If an amplifier company does not provide them, rest assured, there is a reason
Here are the specification for the Devialet Expert 220:
POWER
2x220 Watts RMS under 6Ω
DISTORTION AT FULL POWER
0,0005% THD+N
DISTORTION AT 10W
0.00025% THD+N
Here are specifications for the Benchmark AHB2:
CONTINUOUS AVERAGE OUTPUT POWER
< 0.0003 % THD+N at full rated power, 20 Hz to 20 kHz
- 100 Watts per channel into 8 Ohms, both channels driven
- 130 Watts per channel into 6 Ohms, both channels driven
- 190 Watts per channel into 4 Ohms, both channels driven
- 240 Watts per channel into 3 Ohms, both channels driven
- 200 Watts into 16 Ohms, bridged mono
- 380 Watts into 8 Ohms, bridged mono
- 480 Watts into 6 Ohms, bridged mono
- Rich
Lol. I mean you didn’t prove it’s broke by your test or you conducted in a improper way. Never see any review broke a Devialet, you just so lucky!! Aren’t you.
Anyway, you guys won, looks like you guys have a team here. Can’t beat you. Lol bye. And good lucky with your money hunting review.
Plz qoute a singe credible source to support this "better sounding" nonsense or stop repeating it.
Also, plz quote any designer and his amp where it is clearly stated that such functionality was made intentionally by design in order to improve sound quality.
I think you're missing @Pluto's point...
Rather.I think you're missing @Pluto's point...
Historically, ‘suicidal’ engineering concepts don't seem to have stopped many companies pandering to the audiophile market. If big D does indeed run such an argument, it is far more likely that it will become a mantra amongst les fanbois than an act of suicide.That didn't cross my mind as that would be a true suicidal statement.
Rather.
