Let's see how this "vastly superior" new Devialet model faired in
Stereophile test:
Here it managed to put only 8W when IM test was performed:
" I ran into problems when I tried to test for intermodulation distortion with my usual mix of 19kHz and 20kHz tones. The amplifier went into protection with sustained high-power, high-frequency tones, reducing the output level.
The spectrum in fig.9 was taken at 8Wpc into 4 ohms, the highest power the amplifier would deliver continuously without its protection operating. "
And here it shows non-symmetrical behaviour between left and right channel:
"When I increased the bit depth from 16 to 24 with a dithered 1kHz tone at –90dBFS, the random noise floor dropped by >20dB in the left channel (fig.13, blue trace), meaning that the Devialet's digital inputs offer almost 20 bits' worth of resolution in this channel.
However, the noise floor in the right channel (red trace) is higher than it is in the left and has an odd scalloped appearance. "
And here is how it did on jitter test:
"Finally, tested for its rejection of word-clock jitter with 16-bit USB data, all the odd-order harmonics of the LSB-level, low-frequency squarewave were below the level of noise (fig.16; their correct levels are indicated by the sloping green line). However, a pair of sidebands at ±120Hz to the sides of the peak that represents the high-level tone at one-quarter the sample rate can be seen, these power supply-related.
Note that I had to reduce the volume to "–24" to make this measurement, to avoid the amplifier going into protection. "
Yep, I cannot think of a better word to describe this kind of performance than "superior".
