Denon AVR-X4800H AVR Review
Rate this AVR
    Votes: 10 3.0%
    Votes: 72 22.0%
    Votes: 178 54.3%
    Votes: 68 20.7%
NIN
If you look at AmirM's review - although the wording is "clips" it maintain SINAD above 75db at 2V+
The tech review is not clear as to how much more V it can put out beyond that while maintaining acceptable SINAD (ie at what point does it truly "clip" and SINAD drop off dramatically - at 75db the SINAD is till within the acceptable audibility range!)
What amp are you using?
A small swedish company, Sybarite audio No1200.
NIN
Nice looking amp, but hard to find specifications!! - can you point me to specifications references?
I will ask him (I know the guy making them) what he recommend. Swedish amazon had X4700 for as much as X3800 cost, but it only have 1,4 volt out.
dlaloum
425W @ 8ohm is around 58V
Given a 26db gain, the input V required for an output of 58V is around 3V
so yes... before buying an AVR it's best to check the power amp matching...
dlaloum
The 4800 has no trouble driving the balanced input on bridged AHB2s on the lowest gain setting that’s about 15 db
But the question remains - is it capable of driving the amp to its peak output of 425W @ 8ohm (58.3V)?
HarmonicTHD
Yes but only to
1.5 Vrms in from AVR x 15dB gain = 8.4 Vrms out of AHB2.
Which equals ca 8.9WattsRms out from the AHB into 8ohm nominal speakers.
So not much in my book plus you are underutilizing that nice AHB. But if that works for you.
I’d set the gain higher.
siggen
Is the multitone test at 13 bits not concerning? SOTA is 18 or more bits, but shouldn't 16 bits to at least resolve CD quality be the minimum? There are a lot of positives to the x4800h, but this keeps tripping me up.
pogo
It’s unimaginable that the 4800 would struggle driving 2 surround speakers in any real world setting
The electronics do not care whether a front, surround, ... speaker leads to overload. According to Denon, the impedance must not fall below 3.2ohms. And this is not unusual for a normal 4ohms speaker, if you include the phase. The least that happens is a deterioration of the MTBF. Pre-damage is also not excluded up to an premature failure.
PGAMiami
Yes but only to
Respectfully disagree. The question is not whether the 4800 can drive the AHB2 to full output. Instead it’s whether the 4800 can drive the 4800 to volume levels that are slightly louder than what I could possibly need with my speakers in my room.
PGAMiami
It goes without saying that the electronics don’t care whether the speakers are front or surround. The point I’m making is that there is not much coming out of the surround speakers as compared to the front. And even less if they are set as small with the crossover at 80 or 100 hz. Turn off your fronts and take a listen.
PGAMiami
But reading between the lines of your calculations, I surely don’t need 4 AHB2s in mono. 100 watts should be more than enough. I should try runing my system with just two AHB2s, not bridged, with the gain in the middle setting.
pogo
The problem areas are mostly above 100Hz, see also my example nuLine 34!
When Co-Optimization (DLART) comes soon, more will happen here as well. I run a 4.0 setup with recordings that also demands the rears properly.
PGAMiami
We will just have to agree to disagree.
siggen
This is the test I am referring to -
PeteXian
I am setting up with 4800 and External amps for 5 to 7 Channels for a 5.3.4 or a 7.4.4 HT
I am upgrading my Denon AVR-5600 configured 5.2 HT that uses External Amps on the 5 Kef Reference Speakers and Main L&R Paired REL S-Series Subs are the 500W S510's
How do you like it with the external amps
PeteXian
Do you think the external amps made a noticeable difference? What amps are you using?
PeteXian
I find that I'm using AURO-3D (upmix) with my Atmos movies. The channels are much more active than with Atmos and I'm hearing more detail in the movies. Is there a way to quantify how much more activity there is in the channels and how much power is being used when playing back the upmix?
tesseractASR
Nebraska
That's Analog In. If you are not using that, as most of us are not, it will not matter. If you need it, I'd look elsewhere.
tesseractASR
Nebraska
If someone who owns the x4800h wouldn't mind doing a quick dimension check with a tape measure, I would greatly appreciate it. I'd like to know the exact depth measured from the front of the large volume knob all the way to the back edge of the speaker terminals. (i.e., if you had to put this thing inside a cabinet with nothing plugged in and close the door, how much depth would you need?) (don't worry I won't be doing that)
I understand there are some plugs (and wifi antenna) that would project even beyond the speaker terminals (like the power cord), but just getting this dimension would be super helpful. It's hard to know exactly how they measure it in the specifications.
As a side note, if they could shave an inch or two off the depth of these things it would sure be nice. They do not fit in many tv stands.
Sorry it took this long, but I had abdominal surgery when you posted. Just feeling good enough now to have tried.
17" with a sharp bend in the power cord. I'd want at least 17.5-18".
