I think this review needs a big asterisk and a disclaimer to remind people that the unit is being run beyond reference level. Almost no one does that in their home. The same was true of the X3600H to which comparisons were made. Therefore, most users would never notice the issues called out here.
What reference level? Output volage on pre-out? Is so, reference level as defined by Sony/Philips when they brought out the first consumer digital device was 2 volts. They did this to allow for higher dynamic range as otherwise you would be seriously fighting the noise floor to get down to 1/16 bits. In that sense, higher output voltage is a friend of a DAC designer, not enemy.
AVR companies set these levels based on the internal gain of their amps. That is OK if they don't allow an external pre-out. Because once they do, then the reference level is out of their control. It is whatever the external amp requires to reach its max
and peak power. What produces that power level in the external amp is then the reference.
I provide sweeps anyway for a range of output levels:
As you see I am very clear about the optimal output here being 1.6 volts. No "asterisks" is needed. Even at that optimal output, SINAD is around 86 dB or about 14 bits effective number of bits or way short of what we should be seeing. Since I report the best case output with the amp disconnected, this is actually the final rating in the table:
So overall picture is the same.
