- Joined
- Mar 1, 2020
- Messages
- 479
- Likes
- 853
Ok, so I recorded both preouts and plan to post a link to files so you can all test them. The reason is to find out if Denon 4500 and the likes is enough to play 2 channel music, because AVRs measure poorly most of the time. Or you have to have a separate system for 2 channel music. But first, i wanna explain the chain and i need some advice on level matching.
First, i will be posting three files: The original song cropped to about 90 seconds, song recorded from denon preout and capri preout. Do i keep the original song as a control? I think we need it, but to simplify I can post only recordings. The song is 16bit 44khz originally and i am gonna explain the pathways.
Denon path: PC (windows 10, foobar, wasapi event, realtek onboard) - Toslink - Denon - rca - Capri bypass - XLR - Steinberg UR22 mkII - USB to PC (Windows 10, Audacity)
JRDG Capri : PC (windows 10, foobar, ASIO, XMOS usb driver) - USB cable - Aune S6 DAC - XLR - JRDG Capri - XLR - Steinberg UR22 mkII - USB to PC (Windows 10, Audacity)
All three files will be 90 seconds long in 16bit 44khz format as the original song is. I did record them in 24 bits, but then exported to 16bits so that all three files would be similar. The reason I recorded in 24 bits was because i was afraid that some clipping could occur if the track got hotter in some part and i missed it. Also, i did record them a bit softer then the original, again for the same reason. So now we have original song which is the loudest and recordings which are little softer in volume and not perfectly level matched. To test, they need to be level matched perfectly.
Now i need the advice on that. I was thinking (and already tried it) to use normalize function in Audacity where all three tracks could be level matched perfectly. If you agree that is the way to go, then I am ready to post them. If normalizing is messing with the song, then i can post them raw and someone more knowledgable can level match them digitally with as little messing as possible.
One more thing, i was thinking on naming them in a way that you can't know which is which, and i would send a note to someone at the beginning, so that i am not the only one that knows. This would make it blind testing in a way.
As for the results, i would be open to all solutions. You can ABX them, look at waveforms, whatever. One thing that must be different for all three is noise, so i would disregard that. You can't null them also, because the beginning is not identical, but if you want to sync them, then ok.
I am wainting on your input on how to proceed. If you have any suggestion, please. BTW, I used toslink for Denon instead of HDMI, because it measured better in Amir's test of 4700, and since HDMI is usually worse. But when i listen to Denon, I use only HDMI because of comfort. I hate to switch audio devices.
Thank you
Thank you
