@Ekkoville Even at 2 volts you are only looking at .02 THD+N. At 1.5 volts THD+N is only about .003. In either case neither of you guys will have any problem with the preout voltage. Also with the 3700 you can turn off the amplifiers so the sinad at even 2 volts plenty high.
@Chinaski You typically want input impedance ten times higher than the output impedance.
The only way to turnoff the power amplifiers in the X3700H is to turn off the entire unit.
