- X4700H - MSRP ($1699), 9.2CH (expandable to 11CH [7.2.4] w/2CH amp), 125W, HDMI In/Out (8/3, main/main/Zone 2 outputs) avail mid-June
Upgrading from the X3700H adds: front HDMI input, analog --> HDMI conversion, Zone 3 (same independent inputs as Zone 2 except not HDMI), a 2nd 12v trigger, front panel display of speaker inputs (or outputs), metal front panel with 2 line display, Custom 2 CH main zone settings (using FL/FR or dedicated Front B; LARGE/SMALL; crossover settings, sub – on/off, distance, level), Auro 3D 10.1/Auromatic, AL32 Processing, Bass Sync, same software used on the X8500H for improved audio quality also used on X4700H/X6700H; Remote Control able to store preset codes from other mfr devices (see below) and the ability to add Auro 3D Voice of God/Top Surround via the Subwoofer pre-out 2 only. Audyssey MultEQ XT32 (but not Dynamic EQ, Dynamic Volume, LFC) to be enabled with DTS Virtual:X as well as using Dynamic EQ + Dynamic Volume with IMAX Enhanced DTS:X - these features exist on the X4500H/X6700H and continue with the X4700H/X6700H. Sound quality has been improved (over the X3700H) using the same software technique used with the X8500H.
