If you use external amp to power all channels then the Denon AVR will not have to "power" any of the channels. It will still consume some power because the Denon's own power amps will still be connected to the so called "power rail" so there will be bias currents, and the amps (Denon's) will still be amplifying the input signal voltage, but it won't be delivering currents to the speakers as the speakers will be powered by the external amp. I hope that clears it, if not, just tell us what are your remaining questions.I have read that people write that they get external power to alleviate the burden on the main system, but what burden is being alleviated? The Denon will still be sending full power to all channels (except disabled mains), but then the sound will be driven by the external amp. Across the front, is it a case of the same sonic signature?
Just trying to retroactively make sense of all of this. Thanks.
The preouts send the highpassed signal according to your xover as it should be.OK... next question:
If I am using the pre-outs to an external amp, but my fronts are set to SMALL with a x-over at 60hz, does the pre-out send a full range signal to the amp, or just the signal over 60hz?
Thanks.
Thx... I assumed that... but was just double-checking.The preouts send the highpassed signal according to your xover as it should be.
When Audyssey is in use, sampling freq will be 48 kHz.Hi, I have an x3600h. I'm inputting it into digit coax from an A/D D/A converter + master clock.
I use the Denon for room correction. At what frequency does it work natively?
Should I go in at 96Khz or do I have to go down to 48Khz so that the Denon doesn't perform frequency conversions?
Thank you
Isn't there a possibility to make it work at 96khz? if it only works at 48khz should I give it an input signal at 48khz? or am I wrong? so at least I avoid conversions... maybe. thanks for the link. Thank you
www.audiosciencereview.com
THANK YOU, you're right, sorry. Thanks for the informations.Se il segnale di ingresso sta già campionando a 48 kHz, non sarà necessario convertire. Puoi chiedere a Denon se vuoi una seconda risposta, più autorevole. A proposito, perché ti preoccupi di convertire 96 kHz o più a 48 kHz?
Indipendentemente da ciò, se sei interessato a sapere se la conversione verso il basso introduce problemi udibili, ci sono alcuni collegamenti nei seguenti:
Does sample rate conversion affect sound quality?
I've been wondering if sample rate conversion will affect sound quality. For example, if you're using a Denon receiver with Audyssey enabled, any digital music being streamed through the Denon with a sample rate > 48 khz will be down sampled to 48 khz. Will this affect how it sounds? Also...www.audiosciencereview.com
Come la maggior parte delle cose nell'audio, dipende..., il fatto è che, una volta che dsp è usato, dubito che importi se convertire verso il basso o meno poiché il dsp comporta molto di più della semplice conversione verso il basso da una frequenza di campionamento fissa (44.1, 88.2, 96, 192 kHz ecc.).
Not sure exactly what is being asked between all the different remotes and scenarios, but the stock Denon remote INFO button will display current sample rate, signal type, etc.Does anyone have any idea how I access a button on a remote to view the bitrate on my X3600H display?.. Any way we can access those outside of that world?
Sorry if I rambled.Not sure exactly what is being asked between all the different remotes and scenarios, but the stock Denon remote INFO button will display current sample rate, signal type, etc.
I know! I want to figure out how to program that functionality into my Logitech.Interesting. I've never seen a remote with such capabilities.
Well it looks like you are absolutely set on doing this via IR, and you already know your solution. The aforementioned network protocol solution gets everything on one device, while also having the bitrate and dimming functions you are after. Best of luckI should have kept the Sofabaton. Then I could have taught the buttons to the Logitech. I want to reduce the number of clicks and devices I use. That is why I'm trying to get that functionality in the Logitech.
